It is currently Tue Jan 16, 2018 6:44 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Fri May 18, 2012 4:17 pm
Just wondering if anyone has seen or used these before:
http://www.ebay.com/itm/IO-DuPont-POWER ... 45ec7e550b
Judging from what I've seen of Power Cordz installation, it's a PITA to get them set up properly so I thought this might make it easier.
I'm currently waiting for all my parts for a new build and debating on getting the Power Cordz instead of using the Alligator iLink cables.
PostPosted: Fri May 18, 2012 4:44 pm
Also very interested in this topic. I have a pair of Ax-Lightness Orion brakes and have been unable to find the correct BTP part to allow me to use Power Cordz with this particular brake setup.
Could this bolt allow me to use Power Cordz with the EE Brakes? I have tried the blue rubber groumets sold by Dupont but have been unable to get them to work correctly.
PostPosted: Fri May 18, 2012 5:05 pm
the brakes are pretty easy to do
my experience is the front mech is the only part that is awkward, because it's hard to get the tension correct, but after experiment i found a way that works for me reliably
if you look in this thread i posted some details on how i install powercordz...
viewtopic.php?p=812939#p812939" onclick="window.open(this.href);return false;
overall, whether it's brake cables or gear cables, one of the most important things is getting all the adjusters, mechs etc. in the right place for the install, the settings i indicate work well for me on sram red
also, clamp cables gently until you are sure the tension is correct, you can verify correct operation without fully squishing the sleeve
elsewhere in the thread there're also some posts from people using i-links, and some advice from powercordz too
PostPosted: Fri May 18, 2012 5:47 pm
Administrator
I have a pair of those clasps laying in my desk. If anybody wants them just PM me. No I'm not selling them I'm giving them away.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri May 18, 2012 5:59 pm
Are you refering to the OP ebay bolts or the BTP Ax-lightness device I was asking about? Thanks mark
PostPosted: Fri May 18, 2012 7:50 pm
I'm using Power Cordz with EE brakes, using the stock parts- works fine. Fiddly to setup, but you soon forget that.
PostPosted: Fri May 18, 2012 8:02 pm
Powercordz with AX brakes is a pain, even using the Btp clamp. Setting the tension isn't easy. It works, but it's not great....which describes Powercordz in general. I have an extra set of Powercordz clamps made by Mattius Hellore (in alum) if anyone is interested. It's my last set, and they are a pain to acquire so if anyone wants them, make me a good offer.
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Fri May 18, 2012 8:31 pm
Hi Gumgardner,
Could you post some pics of your bolts and specs if possible?
I am looking at getting some machined up as I can't locate any. :thumbup:
PostPosted: Fri May 18, 2012 9:09 pm
Same thing with me. Pay shipping, and they're yours.
EDIT:In communication with someone. Keep an eye, just in case things fall through :shock:
http://www.wvcycling.wordpress.com/
PostPosted: Fri May 18, 2012 10:28 pm
Pm'd
PostPosted: Fri May 18, 2012 10:52 pm
I will buy the Power Cordz bolts for my Ax-Lightness brakes. PM what price you want. Thanks mark
PostPosted: Fri May 18, 2012 10:58 pm
Very interested in how you tie up the cord on the EE brake clamp. Would love to see a photo!
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
There are no new unread posts for this topic. Attachment(s) Question about sram hidden bolt/non hidden bolt
Chans1ee
Thu Jan 04, 2018 8:42 am
Chans1ee View the latest post
There are no new unread posts for this topic. What does a DT RWS Thru-Bolt do?
Valbrona
Mon Mar 27, 2017 2:28 am
Valbrona View the latest post
There are no new unread posts for this topic. Red 22 ( 2016) b-bolt issue (?)
stormur
Wed Sep 27, 2017 6:15 pm
stormur View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
Users browsing this forum: 4ibanez, akafinto, defbond, fromtrektocolnago, hartox, zulu695 and 44 guests
cron
