It is currently Tue Jan 16, 2018 4:57 pm
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: Nylon bolt uses
PostPosted: Mon Apr 30, 2012 1:51 am
I was wondering about the use of nylon bolts. I already use them for my bottle cages and limit screws. Are there any other safe uses for these. They are so light and cheap that I want to use them for more things. Would they be safe to use for brake mounting (cantilever as well as traditional road brakes)?
My Bike:
viewtopic.php?f=10&t=110318" onclick="window.open(this.href);return false;
 Post subject: Re: Nylon bolt uses
PostPosted: Mon Apr 30, 2012 1:56 am
-to hold cable guide on ( below bottom bracket).
-used a small one for holding the deda fang on (after cutting out some of the band for a 5g net effect)
PostPosted: Mon Apr 30, 2012 2:29 am
Where do you get nylon bolts?
I would love to get some.
Can they really hold a cage with a full water bottle?
Sent from my PG86100 using Tapatalk 2
PostPosted: Mon Apr 30, 2012 2:40 am
I found mine on amazon. Search for
Nylon 6/6 Machine Screw, Pan Head, Phillips Drive, M5-0.8, 25mm Length (Pack of 100)
After cutting them down to about 1/2" (leaving an eight or so beyond inside of threads for a buffer in case they turn loose) they weigh .5 g each. 10g savings over steel for 4 bolts. They seem to hold fine...have been on a half a dozen rides and they have not came loose yet. I gingerly tightened them as i didn't want to sheer off the head or strip out the phillips. I used a black sharpie to color the heads so they don't stand out. I'm using generic ebay carbon cages (they look identical to the bontrager ones).
PostPosted: Mon Apr 30, 2012 4:45 am
Yikes, Im not so sure the nylons are durable enough to stand up to full water bottles. I mean I know this is WW but...
How about at least one Al bolt per cage. :lol:
I used them to plug the rack mount holes on my Kona JTS.
Also most home improvement stores should have them in a few different sizes, Ace, lowes, Homedepot, ect.
PostPosted: Mon Apr 30, 2012 4:51 am
So the chance of both snapping at the same time is minute....if one snaps I'll know, drink or dump the water and deal with it when I get home. I don't think it'll be an issue. Plus...just a water bottle and we are weight weenies, right? lol
PostPosted: Mon Apr 30, 2012 4:48 pm
I use nylon screws on my tune skyline cage, no issues at all.
PostPosted: Tue May 01, 2012 2:44 am
I use them with my Vincero bottle mounts and they hold them in place fine.
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Tue May 01, 2012 3:32 am
Using for the water bottle - Can anyone feel, measure, or try to justify the performance gain over the greater risk......as they will eventually break - and likely when you least could afford it.
I'm a WW but won't go there with nylon "bolts" as they seem to be called.
PostPosted: Tue May 01, 2012 11:51 am
i use them for:
-Bottle cage bolts
-BBcable guide
-F+R deraileur limitation bolts
-Brake shoe anti lose the brake pad bolt (unsure of the technical name)
-B tension bolt on my Sram red rear deraileur.
Thats about all that you can use them for. Saves good weight though :)
I guess there's worse hobbies than making a bike light? Right?
PostPosted: Tue May 01, 2012 1:19 pm
Also the little screw that holds the front mech cages togeather..
I haven't stepped up to limit screws yet.. Do they wear out?
Skunkworks Bikes
PostPosted: Tue May 01, 2012 1:25 pm
Neat idea :P
Skunkworks Bikes
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
There are no new unread posts for this topic. Attachment(s) Question about sram hidden bolt/non hidden bolt
Chans1ee
Thu Jan 04, 2018 8:42 am
Chans1ee View the latest post
There are no new unread posts for this topic. What does a DT RWS Thru-Bolt do?
Valbrona
Mon Mar 27, 2017 2:28 am
Valbrona View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
There are no new unread posts for this topic. Red 22 ( 2016) b-bolt issue (?)
stormur
Wed Sep 27, 2017 6:15 pm
stormur View the latest post
Users browsing this forum: Asteroid, Bing [Bot], Chris3g and 42 guests
cron
