Which stem 73 degrees or 84?
I have both and find that it depends on the frame. Because different frames have different angles in sloping top tubes, I like using the stem that matches the angle. So for my Wilier and Storck, I use a -6 and for my BMC it's -10. I compensate the difference in height of the two stem angles with fewer or more spacers.
Looking at the saddle to h'bars drop of many pros will suggest low is good - but please base your stem choice on what works for you and for your given bike.......as manufacturers now offer a wide variety of head tube heights - and when combined with effective TT lengths and rider "styles" this doesn't allow for single stem angle recommendation.
Maybe post a pic of you on your current bike and I'm sure you'd get plenty of more insightful recommendations from WW members........
How do you feel on your bike now? Do you feel too high when riding the top and hoods? Do you feel the drops to be too high? Are you straining to get into the drops, but the top portion feels good? I know it may look cool, but that only matters when you are resting and staring at your bike. Bombing a hill on your tops b/c the drops are uncomfortably out of reach is both "ugly" and potentially dangerous ... just my two euros.
It's seems fine as it is but I can never tell, I play quite a lot with the hight, I use to have spacers and I cut the fork so this is basically where I felt I want to be but I'm curios about the flat stem position with no raise since I have no idea how I would feel. Also I have 5 mm of spacer Right now i can play with.
I am here: http://tapatalk.com/map.php?axzxhl
- Similar Topics
- Replies
- Views
- Last post
- 6 Replies
- 541 Views
Last post by Fiery
Sun Feb 11, 2018 9:59 am
- 1 Replies
- 2056 Views
Last post by MayhemSWE
Wed Jul 19, 2017 7:04 pm
- 21 Replies
- 2399 Views
Last post by misterq
Thu Nov 02, 2017 8:48 pm
- 7 Replies
- 288 Views
Last post by REGICYCLE
Thu Mar 29, 2018 10:04 pm
- 9 Replies
- 1600 Views
Last post by benhama
Wed Aug 30, 2017 9:55 am
