It is currently Fri Jan 19, 2018 8:45 am
PostPosted: Sun Apr 29, 2012 9:21 am
Location: somewere floating between here and the other side
im in the procces of chancing from xo to xtr and im wondering if a xo front derailler works on a xtr shifter ?
thanks mick
PostPosted: Mon Apr 30, 2012 5:13 pm
M970 and older will, not sure about M980.
Rears won;t work though.
Blog http://andrewhowett.blogspot.com"
PostPosted: Mon Apr 30, 2012 6:40 pm
All front derailleurs/shifter combos should work between SRAM and Shimano.
Stefan
PostPosted: Tue May 01, 2012 1:22 pm
thanks !
PostPosted: Sat May 05, 2012 1:29 pm
Stefan- does that include road derailleurs with XTR shifters? I would like to use a Dura Ace front dérailleur with my new build.
PostPosted: Sat May 05, 2012 1:58 pm
7900FD+M980 shifter works well on 2 chainring (middle+small)
PostPosted: Sat May 05, 2012 3:19 pm
Thanks Sonny, this is what I plan on running. Any modifications to the derailleur needed?
PostPosted: Sat May 05, 2012 3:57 pm
nothing to modify - install, adjust and ride !! :thumbup:
(keep the M980 shifter on 3X mode)
PostPosted: Sat May 05, 2012 7:05 pm
Why is that? Will it not pull enough in 2X mode.
PostPosted: Sun May 06, 2012 1:56 am
From my experience, cable pull of 2X mode is not enough, just keep it in 3X mode and adjust the H screw to limit the fd to reach the middle ring is ok.
There are no new unread posts for this topic. modifying shimano 685 front shifter for 1x
simoncx
Tue Dec 05, 2017 12:06 am
simoncx View the latest post
There are no new unread posts for this topic. Attachment(s) XTR Di2 full rear gearing set (derailleur,shifter,information display)
bikemaniack
Sat Nov 25, 2017 11:24 am
bikemaniack View the latest post
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
1424
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. SRAM Red Front Derailleur Tuning (YAW)
prendrefeu
Wed Jan 10, 2018 12:45 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Sram Etap Front Derailleur Height
goldmine848
Thu Jun 22, 2017 10:25 am
goldmine848 View the latest post
Users browsing this forum: No registered users and 4 guests
cron
