It is currently Sun Dec 17, 2017 12:05 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Apr 27, 2012 2:06 am
Here is what I'm thinking.
Rims: Farsports FSL50-TM at 350g each
Spokes: CX-Ray
Hubs: Bikehubstore superlight 277g/pair or Hubsmith at about 255g/pair
I'm under 65kg so what will 16/20 or 16/24 spokes do? I like the idea of 24 spokes out back since it allows for 16:8 drilling and more even tension. The 16 spokes up front will give a very slight weight and aero advantage. Will this be stiff enough at my weight? The Hubsmith hubs may not be available in 16h front or 16:8 drilling rear; I'll have to ask.
My clincher wheels are Kinlin XR-200, BHS Superlight hubs & Revolution spokes. Laced up 20/24 with 16:8 out back they are 1265g.
PostPosted: Fri Apr 27, 2012 4:00 am
I'm 65kg and hard on rear wheels. 24h on a deep section carbon rim is fine for me.
FarSports basalt brake tracks work pretty well for me.
PostPosted: Fri Apr 27, 2012 4:25 am
Eric any idea what the rims ended up weighing? What sort of pads are you using on them?
PostPosted: Fri Apr 27, 2012 4:38 am
Mine are 50mm deep clinchers- 406g and 410g.
I'm using Reynolds blue pads, which look similar to the FarSports pads.
PostPosted: Fri Apr 27, 2012 6:41 pm
i have just checked on Farsports website but i can't see any price for the rims, do you need to contact someone or i missed something?
Thanks
My 1998 Trek 5220 paint stripped 6.41Kg
PostPosted: Fri Apr 27, 2012 7:48 pm
sales4@farsports.cn worked for me.
PostPosted: Sat Apr 28, 2012 1:15 am
My Farsport 50mm clinchers are 20/24 and are super stiff (I am 75kg). At 65kg 16/20 would probably be stiff enough for you.
On the other hand 16/20 does not offer much weight advantage over 20/24... so going with 20/24 and being assured of stiff wheels seems the best choice.
This is my no name bike
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=81279
-caseycycling
There are no new unread posts for this topic. Are all cogs of the same tooth count the same diameter?
Shrike
Sat May 20, 2017 8:20 pm
2lo8 View the latest post
There are no new unread posts for this topic. Help me get some tubulars
zalle
32
2778
Fri Mar 10, 2017 2:51 pm
Geoff View the latest post
There are no new unread posts for this topic. Dye-ing tubulars
NiFTY
7
1027
Mon Jan 09, 2017 10:01 am
MJB View the latest post
There are no new unread posts for this topic. open tubulars
bennybikes
Fri Nov 03, 2017 4:36 am
vanillaflyweight View the latest post
There are no new unread posts for this topic. Michelin Pro4 Tubulars
russianbear
Mon Feb 27, 2017 7:51 am
superdx View the latest post
Users browsing this forum: Google [Bot], reknop, TobinHatesYou and 27 guests
