It is currently Mon Dec 11, 2017 2:45 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page 1 2 3 Next
 Post subject: Tune Mag 170 feedback
PostPosted: Sat Apr 21, 2012 11:02 am
I have a Tune Mag 180 on one of my wheelset, after the initial creaking issues it has been trouble free for a couple of years now.
I am looking at a new build and the Mag 170 is the new version of the 180. Any feedback from people who have been on the 170 for a while ?
Thanks
PostPosted: Sat Apr 21, 2012 1:07 pm
I believe Tune recently modified the 70/170 hubs, dropping the XO bearing and increasing the axle width among other refinements. I had the prior 70/170s and liked them a lot after the creaking was easily and quickly solved under warranty.
I now have the new version 70/170s on a pair of Enve 3.4s and after six months have been very happy with them: look great, work fine, no problems; however, the freehub/ratchet is pretty noisey so you won't sneak up on anyone...
http://fairwheelbikes.com/cycling-blog/updates-and-news/rear-hub-noise-comparison.html
Wilier Cento1 SR
13.10 lbs (5.95 kgs) w/Enve 3.4-Tune 70/170 & Conti Competitions tubulars
12.53 lbs (5.68 kgs) w/FarSports 24-Extralite & Vittoria CX EVO II tubulars
PostPosted: Sat Apr 21, 2012 3:13 pm
Thanks
I had the Mag 180 and had the creaking issue. I sent it back in under warrantee a few months ago, the Tune warrantee fix worked for about 3 months and the creaking returned. I was told that it would probably be a continuous problem because of eventual play between the XO bearing and ring. Not wanting to deal with that, I was offered a trade-in of my old 180 toward the new 170. I should receive the wheel today and hope to have a trouble-free hub, they are super smooth hubs.
http://ddubcustomsportswear.com
PostPosted: Tue May 01, 2012 1:45 pm
Have had both. 180 had drag issues and some creaking. The 170 has been good so far. No issues
Sent from my A500 using Tapatalk 2
N+1 It Never Stops
PostPosted: Wed May 02, 2012 1:03 am
As mentioned by others.....the 170 is a nice upgrade from the 180 with bigger bearings, no need for special tools, the XOT bearing is gone and a 17 mm diameter axle. All this translate into a sturdier hub that actually weight a bit less. So far from all the builds we have done with the 170 the feedback is very good.
www.royalbicycles.com
PostPosted: Wed May 02, 2012 4:49 am
I had 3 Mag180 and all of them had the creaking issue.
But all solved.
smoothness are different among them, I found out that it is due to the o-ring.
I am using 2 Mag170, very nice upgrade
no creaking issue, 17mm axle, bigger hub shell, light and strong, improved and nice geometry
I wish to have my 3rd Mag170, but will tune provide a new freehub for Shimano11sp?
it is my understanding that there are 3x6803 and 1x6903 in Mag170 (static load 1305)
static load of Mag180 is 1306? (6802/6902)
PostPosted: Wed May 02, 2012 5:12 am
off topic here
I have a Mag150 that creaks. When i take the cassette out and grease the freewheel the creaking stops for a few week.
Is this the same creaking issue you guys are talking about?
2012 Scott Foil Premium
PostPosted: Wed May 02, 2012 12:33 pm
We have found on mag 180/150 that the creaking can be a XOT bearing that has become loose.
This special bearing is bonded with green loctite to the hub shell but with time or if you use harsh degreasers/cleaners it will become unglued.
They tend to move a bit due to the previous design with a smaller diameter axle and XOT bearing causing the creaking noise.
You can try to take apart the hub (be careful if you don't have the Tune tools not to damage the carbon axle) and check that all bearings are bonded.
Instead of green loctite we had great results with Tef Gel which is a thick antiseize/anticorrosion grease we have been using on wheel nipples.
Of course if you again clean your bike a lot with degreasers over time you will have to relube/bond the bearings again.
Also check the freehub bearings if it rides smooth and on the Mag 150 the number of shims you have to adjust preload.....these hubs with carbon axle can't be adjuted like the Mag 180/170.
PostPosted: Wed May 02, 2012 4:51 pm
I fixed my Mag180s by doing this
sanding...
PostPosted: Sat Jun 02, 2012 3:10 pm
Thanks
Put 1500mi. on the new Mag 170 hub.....now CREAKING! This is so frustrating considering that the new version supposedly fixed this issue. I'll have to call FairWheel Bikes (who sold me the hub) and find out the next step. My Bike Hub Store hub has been more durable than this supposedly "higher quality" hub.... :evil:
PostPosted: Sat Jun 02, 2012 4:54 pm
oh..i am sorry to hear about that
But My 170 still work perfect now while my bikehubstore and dati hubs keep creaking...(otherwise I would love dati hubs)
PostPosted: Sat Jun 02, 2012 7:42 pm
Razor wrote:
Thanks
NOT GOOD! I hope this is not going to be the same nightmare as the 180. My rear wheel just got a new 170 to replace my 180.
PostPosted: Sat Jun 02, 2012 9:38 pm
LionelB wrote:
Razor wrote:
Thanks
I hope you have better luck than I have. Recently, the hub started to make a clicking noise so I thought the skewers were loose. I lubed the rear drop out/skewers ends, tightened it down. The noise went away for a day or so, then yesterday it went full on creak. Tried different skewers, same noise (I've become an expert at the "Tune Creak" lol), swapped out wheels with same skewers....noise gone. I'll post an update when I contact FWB.
PostPosted: Mon Jun 04, 2012 12:32 am
I purchased a set of light weight clinchers from Fairwheel with Tune hubs (Mag 180), it started to creak/crack after 2 rides. I tried a couple remedies from this forum with no success. I sent the wheel back to Fairwheel for them to try to fix it but when I got it back it started creaking on the first ride. I sent the wheel back to get it replaced with the Mag 170.
I have ridden the Mag 170 for around 700 miles and it started to make a consistent crack sound today. (similar to the crack/creak on the Mag 180 but not as loud) :noidea:
time to look for a new brand of wheels no Tune or C-4 for me
PostPosted: Mon Jun 04, 2012 1:14 am
Wow, sorry too hear that as your experience almost mirrors mine. I am wondering if there was a bad batch of hubs coming out of FWB or has Tune really not addressed the issues they had with the Mag 180?
There are no new unread posts for this topic. Rim brake advice and feedback needed
woogie11
11
791
Sat Aug 26, 2017 11:40 am
Marin View the latest post
There are no new unread posts for this topic. WR Compositi Rims- thoughts & feedback
Wookski
Sun Mar 12, 2017 6:15 pm
Seedster View the latest post
There are no new unread posts for this topic. First power meter - guidance and feedback please
MichaelB
18
1315
Sun Nov 26, 2017 2:07 am
MichaelB View the latest post
There are no new unread posts for this topic. Speedplay Tune ???
1spd
16
1985
Thu Apr 06, 2017 1:19 pm
kode54 View the latest post
There are no new unread posts for this topic. Tune freehub
steelme
7
796
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
Users browsing this forum: benjaminm3, Bing [Bot], joeyb1000, Maddie, mike, Mockenrue, Titusrider and 29 guests
