It is currently Sat Jan 20, 2018 4:34 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Apr 24, 2012 7:38 pm
She's now down to 4.94kg after switching out the brakes. Went from Feather (199.1g) to the new 2012 Ciamiilo CF Gravitas SL (162.6g). I had to add couple of Nokon links since to the rear since the new arm is a little shorter than the feather.
One question I have, should I sand off the white skull winged logo or keep them?
File comment: Feather brakes
File comment: 2012 Ciamillo CF Gravitas brakes
Parlee Z3 4.94kg: viewtopic.php?f=10&t=101920
Wilier Cento Uno SL 5.52kg: viewtopic.php?f=10&t=101957
PostPosted: Wed Apr 25, 2012 1:57 am
Sand them off. That's the only part of those brakes that I don't care for. The skull thing is so cliché... and doesn't quite make sense on bicycle brakes.
____o
_`\<,_
PostPosted: Wed Apr 25, 2012 3:03 am
I say keep them, I think they're badass
PostPosted: Wed Apr 25, 2012 3:53 am
Hey! Its du from garden grove, nice to see you got your ride up and running. From what you told me I didn't think it would be this light, and with a good amount of reasonably easy grams to shave too! I think a syntace stem with ti bolts would work well with this build and save almost 20 grams
PostPosted: Wed Apr 25, 2012 2:51 pm
Yup the skulls are bad arsed! And forget the syntace stems... They are for MTBs and those that won't spend the coin on an extralite OC. You don't appear to be pulling punches so it's a no brainer :mrgreen:
Skunkworks Bikes
PostPosted: Wed Apr 25, 2012 6:07 pm
I have a Rotor S3 stem that will help me loose ~17g (126g to 109g). I think an Extralite 120mm stem is ~100g, so not sure what I'm going to do yet. I may change out the bars when I decide on a stem. I like contoured bars so the ultralight ones are out. Was thinking the Zipp Contour SL SS ~190g, but only saves ~15g over the Enve on her now. Part of me thinks I should stay with the Enve cockpit since it looks so good with the frame/fork even though I would loose 30-45g. I figure I can lose ~100g switching out the pedals (Aerolites) & switching out the cages to BTP I will lose ~50g.
PostPosted: Wed Apr 25, 2012 6:11 pm
It's the wheel set (RZRs-878g), light Tufo tubs (<240g for the pair) & the Berk saddle/post combo (~119g) that has kept the bike so light.
PostPosted: Thu Apr 26, 2012 3:35 pm
beautifully done bike. I wish I was smaller, I could never hit that weight (stupid 60cm frame).
There are no new unread posts for this topic. Umm.. odd request. Looking for a large poster for indoor trainer room. Alps, bike race on cobbles. Realistic looking.
Shrike
16
2019
Fri Jun 02, 2017 9:08 am
kaguri View the latest post
There are no new unread posts for this topic. Lower back not letting me ride... Help!
in Training
zalle
18
1502
Tue Apr 18, 2017 8:49 pm
Rick View the latest post
There are no new unread posts for this topic. BMC teammachine lower bearing spec?
xcnick
Sun Nov 12, 2017 4:28 pm
xcnick View the latest post
There are no new unread posts for this topic. Chain falls off lower jockey wheel SRAM Red 22
octave
Sat Feb 04, 2017 9:06 am
Tom14 View the latest post
There are no new unread posts for this topic. Help with finding a replacement Canyon lower headset bearing
jimwhimpey
Tue Oct 03, 2017 9:43 pm
jfranci3 View the latest post
Users browsing this forum: Wookski, Yahoo [Bot] and 9 guests
cron
