It is currently Thu Jan 18, 2018 9:15 am
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Cervélo R5 VWD, 5,1kg
PostPosted: Fri Apr 13, 2012 11:54 am
Moderator / Brake Pad Boy
I just finished my latest build: Cervélo R5 VWD:
First the complete build list:
Frame Cervélo R5 VWD size 51 (incl. bb) 830gr
Fork Cervélo SL 285gr
Headset FSA Orbit 86gr
Stem KCNC SC Wing 120mm 108gr
Handlebar Easton EC 90 SLX 198gr
Seatpost MCFK Zero Setback 96gr
Saddle AX Lightness Phoenix 67gr
Seatpostcollar MCFK Carbon 7gr
Rear derailleur Sram Red 130gr
Front derailleur Sram Red 71gr
Crankset Campagnolo Super Record Ti, 34-50 626gr
Pedals Look Keo Blade Carbon 185gr
Brake front Negative Gravity GSL 97gr
Brake rear Negative Gravity GSL 96gr
Cassette Sram RED 11 23 153gr
Chain Sram 240gr
Wheel front AX Lightness 24mm/Tune Mig70/DT Revolution 20 370gr
Wheel rear AX Lightness 24mm/Tune Mag170/DT Revolution 24 500gr
Shifters Sram Red 288gr
Tape Deda 38gr
Tires Vittoria CX II 430gr (2x215)
Bottlecages Tune 18gr (2x9gr)
QR's Tune DC16/17 remake 44gr
Exxpander Cervélo expander 25gr
Spacer 25mm 6gr
Cable Elvedes prototype 20gr
Cable outer Alligator I-Links/Alligator I-link Mini 65gr
Total 5.1kg
Colnago extreme-C Scott Addict SL
PostPosted: Fri Apr 13, 2012 12:52 pm
Very nice build!
https://twitter.com/#!/DiMiTrIdA
PostPosted: Fri Apr 13, 2012 1:22 pm
Really nice build :thumbup:, low profile wheelsets suits very well on R-series Cervelo frames.
Is that seatpost collar one-off piece, or does MCFK sell those?
PostPosted: Fri Apr 13, 2012 1:57 pm
Grear biuld. I would just change the stem. Kcnc looks very cheap next to the rest of the gear.
PostPosted: Fri Apr 13, 2012 3:06 pm
Is therre anything that you can do to get this to 4999g. It looks so close to being under 5kg
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Fri Apr 13, 2012 3:11 pm
Yup... Stem, bars, expander, tires, and the QRs.... Plus a few alloy bolts here and there. :mrgreen:
Skunkworks Bikes
PostPosted: Fri Apr 13, 2012 6:38 pm
Very light bikes often look ugly, but this has both weight and looks on its side. Chapeau sir, but 4,999, yes.
PostPosted: Fri Apr 13, 2012 9:11 pm
Great looking bike. I really like Cervelos with the shorter head tube, Once they go over 54cm they loose the stealthy look . I think the older bikes looked better with the shorter head tube .This bike looks super and a nice choice of components .
:beerchug:
PostPosted: Sat Apr 14, 2012 3:57 pm
really nice bike
why this crank ?
PostPosted: Sat Apr 14, 2012 6:32 pm
Great build - with the AX rims it looks like it would murder the hills alright! :beerchug:
PostPosted: Sun Apr 15, 2012 5:11 am
Very nice build :thumbup:
Frankly though, I find the frame weight quite disappointing given the price difference between the R5 and R3, I would have thought the latter would be in the same ball park as yours, weight wise at least for a 51cm.
Norwood & Adelaide Uni CC
PostPosted: Tue Apr 17, 2012 3:44 pm
Thanks for the comments and positive criticism. Optically, the looks of the high profile EDGE wheels unsurpassed, but in view of the weight is the AX Lightness set the only correct choice.
Regarding the weights of some elements, there is a small number of parts: unfortunately relatively large essential parts; such as frame, fork and crank that I didn't weight for myself. These are thus estimates. I'm very curious to the exact weight of the frame in this particular bike.
To answer the question for my choice of Campagnolo Super Record UT crankset, Campagnolo's crankset is actually a very good option. I do not like the looks of the Rotor's crank yet I do love THM's Clavicula M3 crank. However, since this would be over 400, - euro more expensive, the weight difference would be +/- 100gr and still had more than 6 weeks for delivery, I opted for the Campagnolo crankset. Chances are here in the future an upgrade occurs.
Sub 5kg will be within reach, most certainly when the crankset would be upgraded with the THM crank. Yet some further tuning is possible such as: Shifter clamps, bolt tuning and some other parts.
PostPosted: Wed Apr 18, 2012 2:39 pm
Location: Lima, Peru and occasionally in the Washington DC area.
Awesome bike Jip. As others have said, ultra weenie bikes are usually not aesthetically pleasing. This one is light and beautiful.
Bravo.
PostPosted: Fri Apr 27, 2012 3:49 pm
Jeez what a rig, well done man! :unbelievable:
PostPosted: Fri Apr 27, 2012 8:52 pm
Stunning! Incredible wheels. 870g for the pair!
Not at all keen on the campagnolo/SRAM mix. Go for rotor.
Caad10 with Campagnolo
There are no new unread posts for this topic. Cervelo S2 DA Di2
Beancouter
20
4209
Wed Jul 26, 2017 4:31 pm
mr.wulf View the latest post
There are no new unread posts for this topic. Cervelo R3
itguy
Thu Apr 27, 2017 8:50 am
itguy View the latest post
There are no new unread posts for this topic. Cervelo S3
trilocus
Sat Dec 16, 2017 3:48 pm
trilocus View the latest post
There are no new unread posts for this topic. Cervelo R5
[ Go to page: 14 5 6 7 8 ]
NYCPrynne
118
19026
Wed Jun 28, 2017 3:50 pm
wingguy View the latest post
There are no new unread posts for this topic. Cervelo S1
mannequinforce
9
1648
Wed Apr 26, 2017 6:01 pm
tmr5555 View the latest post
Users browsing this forum: campbellrae, Google [Bot], Google Adsense [Bot], JS300 and 14 guests
