slim top cap for cane creek headset ...
itsacarr
by itsacarr
Do any exist?
Think in the same vein as the cannondale top cap to the headset assembly ... I would have used it on the cane creek headset but the top cap needs to be stepped on the inside to sit properly. The one that comes with is too tall for how low I want the stem given how much taller my new frames head tube is ... thoughts?
VTBike
by VTBike
I'm not exactly sure what your talking about - but I'm using a parts of passion carbon topcap that I bought at Fairwheel, which is literally wafer-thin carbon. Fiberlite also makes one. I like the look much better than the large rounded topcaps.
fletch62
by fletch62
I presume he means the top headset bearing cover, which are generally 15mm or more.
Flybikes, a BMX company make one of the lowest but dont know if it works with Cane Creek.
hmai18
by hmai18
STARNUT wrote:Cane Creek sells their headset uppers and lowers individually. The upper you're after is SHIS:IS41 - 1-1/8" Cane Creek Integrated Threadless. Or just the IS41 upper. Believe it's a 5mm stack. You should able to replace the bearing, compression ring, and cone for <$30.
Starnut
I believe you should be able to use any cover from a Campagnolo standard headset. I'm currently using one from FSA on my CAAD10.
nathanong87
Resident master of GIF
by nathanong87
itsacarr wrote:Do any exist?
is42 that's what u want, thats what u need.
NGMN
by NGMN
I've been searching for a replacement for my Cyfac, and just ordered an Eastern(like flybikes it's usually used on bmx bikes) IS42, Campy style 45/45 bearing headset. Looks to be about 7-8mm in height. Based on your description of the inside of the bearing cover, that sounds about right; but I'd check on your exact headset type.
Remember Cane Creek is a fairly generic headset description; they make all sorts of headsets.
btompkins0112
by btompkins0112
This might work.....compatible with CAAD10, EVO, etc......may would need to use a cassette spacer below it :noidea:
http://slamthatstem.com/headset-bearing-cover
