It is currently Fri Jan 19, 2018 6:44 am
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Mon Jan 12, 2004 11:45 pm
I generally switch between two cassettes, both Record Ti/Steel cassettes, one is an 11-23 and the other a 13-29. I use the 13-29 for the extremely hilly rides I occasionally do. To avoid uneven wear (and obviously for capacity issues) I switch the chain out also (and derailleur).
Here's the question .. I was pondering using the American Classic cassette for some crits (127g). It's very light but I wonder about performance and wear. their own site says 1000 miles. Is the weight savings worth it .. i.e., if performance sucks I may not even attempt it. Also, is it recommended to get a new chain every time the cassette is replaced?
http://www.amclassic.com/Cassettes_Alum.html
Another question: what do you think is the ideal cassette for a good compromise between weight and wear? I was considering the All Ti Record but it's awful pricey. I've had excellent performance with Record Ti/Steel (so far).
There are no new unread posts for this topic. aluminum ww build
Rubik
Fri Jul 07, 2017 5:09 pm
HeluvaSkier View the latest post
There are no new unread posts for this topic. What is the current king of aluminum in 2017?
Ahillock
32
4788
Fri Jul 14, 2017 3:00 pm
bremerradkurier View the latest post
There are no new unread posts for this topic. Looking for compact aluminum handlebar under ~260 grams
mpulsiv
21
2336
Thu Feb 02, 2017 11:14 pm
DutchMountains View the latest post
There are no new unread posts for this topic. Galvanic Corrosion on Aluminum Insert with Carbon Seatpost
RyanH
18
1518
Fri Jun 16, 2017 10:06 pm
Calnago View the latest post
There are no new unread posts for this topic. Ultegra 8050 front derailleur aluminum back plate
ParisCarbon
Sun Nov 05, 2017 5:21 pm
DeeHubbs View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], gospastic, MagicShite, mogwaiboi and 39 guests
cron
