It is currently Tue Jan 16, 2018 10:42 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sun Apr 08, 2012 8:31 am
Hi All,
About to install dura-ace 11-25 cassette on a new set of Zipp Firecrest 404 (beyond black) wheels.
Usually I would use a thin spacer between the hub and the cassette. However I believe that the hub that comes with new 404's is specifically 10-speed thus not requiring the spacer.
Can anyone please confirm if the spacer is required? ( The shimano instructions stipulates the use of spacer on a 9-speed freehub body). However I think that new zipps come with 10-speed hub body.
Thanks
PostPosted: Sun Apr 08, 2012 8:41 am
can't see it being shimano 10-speed only as that would prevent use of sram cassettes wouldn't it?
PostPosted: Sun Apr 08, 2012 8:48 am
thanks sungod.
That implies that the freehub is your standard 8/9/10 speed and hence requires usual 1mm spacer?
I've identified the hub as 188.
http://zipp.com/technologies/hub/88-188-hubs.php
PostPosted: Sun Apr 08, 2012 11:17 am
yes, will be a spacer with a shimano 10-speed cassette
PostPosted: Mon Apr 09, 2012 3:28 pm
thanks sungod.
If I understand zipp tech doco's correctly, the 188 free hub that comes on 2012 404's is designed for 10 speed cassettes and requires no spacer. So I am still little confused.
Has anyone installed shimano cassette on new set of zipps?
Thanks
PostPosted: Mon Apr 09, 2012 4:22 pm
Yes, I run a dura ace 10 speed cassette on my 188 hub. sungod is correct, you will need to install the spacer.
PostPosted: Mon Apr 09, 2012 4:25 pm
Install it without one if you like. Will be obvious if it's needed or not once you get the lockring on.
There are no new unread posts for this topic. Zipp hub 177 and Shimano cassette issues
dorin
Wed Jan 25, 2017 3:48 pm
joejack951 View the latest post
There are no new unread posts for this topic. Real world use of ZIpp 404 firecrest - I am struggling. Advice req.
[ Go to page: 1 2 3 4 ]
diegogarcia
57
5536
Thu Apr 27, 2017 8:51 am
yongdaeok View the latest post
There are no new unread posts for this topic. Shimano 11-30 cassette with 9070 Di2
mnmasotto
7
938
Tue Sep 12, 2017 3:24 pm
MXGimp View the latest post
There are no new unread posts for this topic. Cassette for 10 speed shimano
vejnemojnen
Sun Jan 14, 2018 10:22 am
vejnemojnen View the latest post
There are no new unread posts for this topic. Attachment(s) SRAM or Shimano 11 speed cassette
DeLuz
42
4109
Mon Jan 01, 2018 4:54 am
fh8425 View the latest post
Users browsing this forum: Asmith, Bing [Bot], Google [Bot], Konsta, micky, snowdevlin and 51 guests
cron
