It is currently Fri Jan 19, 2018 7:09 am
PostPosted: Thu Apr 05, 2012 11:00 am
Can't say I am a fan of the E-type mech so what are alternative mechs?
Seat tube is around 39.0 mm and 3 rings up front.
Anyone know why Scott chose to fit the E-type mech - for example the CF tube too weak to take a clamp on mech?
PostPosted: Thu Apr 05, 2012 12:12 pm
Scott seem to like E-type, not the best but they do work, alternatively get a machine shop to make you up a 39mm clamp and then use a bolt on.
PostPosted: Thu Apr 05, 2012 7:55 pm
This was addressed here: viewtopic.php?f=1&t=98198
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Fri Apr 06, 2012 1:35 am
Or if you can find an old Sachs Top-pull Braze-on FD and a light 39mm carbon clamp and tune it with dremel and aluminum bolts, you can go sub-100g.
Here's are related topic:
http://weightweenies.starbike.com/forum/viewtopic.php?p=266491
PostPosted: Fri Aug 17, 2012 10:27 am
.... back to this - sram xx is shown as 38.9 mm clamp (high clamp - needs to be in order to clear the non-round section of seat tube) - i measure seat tube to be 39.0 mm so will tht fit without damage to the tube?
xx is 2 ring - will it work with 3 ring set - (22-44)
or maybe direct mount with custom clamp - anyone come across something like that?
hmmm, i wonder how difficult it would be to make something like this: (assuming it is not available in 39 mm dia)
or use a carbon seat clamp - anyone tried bending theseto fit a seat tube?
PostPosted: Tue Sep 11, 2012 9:41 pm
I'm running the carboncycles carbon seat clamp with a custom bracket and Sram Road front mech, on a 2010 Scott scale 35. It took a bit off playing around and test fitting to get the right amount of clamp force on the seat tube and bracket but it works fine for me. I lubed up the seat tube to install the clamp because it has to stretch a long way to slide on but there were no cracking noises. Can't find the weights at the moment but its light. my main reason was i wanted to run a double ring chainset, and couldn't find a decent light solution.
will try to post a picture.
PostPosted: Thu Apr 18, 2013 1:34 pm
.... resurrecting an old thread - SRAM XX front mech if for a 2 chainring set up?
PostPosted: Thu Apr 18, 2013 6:23 pm
I got a Sram XX 38.2 mm high mount toppull front derailleur for sale if you are interested - had it on my Scott Scale :-)
119,5 grams.
My blog
There are no new unread posts for this topic. Scott Scale 26" Bike Options--Weight vs Price--Pay More for Bike or Just Upgrade?
sandico
Tue Apr 04, 2017 6:14 pm
poynt View the latest post
There are no new unread posts for this topic. Scott Scale Ltd
02GF74
Wed Nov 08, 2017 9:42 pm
02GF74 View the latest post
There are no new unread posts for this topic. Upgrade for a Scott Scale 920.
in MTB
batcave
Tue Jul 04, 2017 1:47 pm
TheRookie View the latest post
There are no new unread posts for this topic. FS: Scott Scale LTD frame, NEW
rainerhq
Fri Oct 27, 2017 11:27 am
rainerhq View the latest post
There are no new unread posts for this topic. Converting Scott Scale from 2 x11 to 1 x 11
in MTB
ironman1
11
1190
Sun Jun 18, 2017 1:59 pm
Dilbert View the latest post
Users browsing this forum: No registered users and 6 guests
