It is currently Tue Oct 17, 2017 3:36 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Apr 03, 2012 11:54 pm
Quote:
but how much do their multiple layer-brass cleat weigh? Does weight bolted to your shoes not weigh as much as weight bolted to your bike?
If you're just fixated on making a light bike... it does not matter, but that extra cleat weight, when riding, you're still having to pull around. That's why shoe companies keep trying to make lighter weight shoes.
PostPosted: Wed Apr 04, 2012 10:23 pm
mdeth1313 wrote:
I'll stick with my exustar 200 ti pedals. 178g for the pair and less than $200.
Easy to pick up Keo Blade Cromos for $150 brand new on eBay. Get a pair of Ti spindles for $60 and you're just at about $200.
Flickr
2012 Cannondale CAAD10
 Post subject: Look Keo Blade Tuned?
PostPosted: Wed Apr 04, 2012 10:38 pm
Which aftermarket spindles suit the Blade? (& who sells them) I couldn't see any on Wards website?
Sent from my iThingy using Tapatalk
PostPosted: Thu Apr 05, 2012 12:04 am
Ward sells them on eBay. Just search look titanium spindles...
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Thu Apr 05, 2012 12:59 am
They won't come out and tell you which ones work with the blades. When I asked, they emailed me a comment from a user saying they worked, but they wouldn't confirm it.
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Thu Apr 05, 2012 1:25 am
Ward states in his ad that it works with the blades.
Flickr
Follow on Instagram
PostPosted: Thu Jul 26, 2012 3:00 am
Do you guys know if there is a version for the Keo 2 Max pedals. Wonder if it would be worth the swap.
PostPosted: Thu Jul 26, 2012 6:33 pm
They all share the same spindle. I am using Ward Ti spindles on Keo2Max, Keo2Max carbon and blade.
They also make a loger version for those who prefer a wider stance. They are 6.5mm wider.
PostPosted: Thu Jul 26, 2012 9:28 pm
Awesome! Their description seems to be outdated as it says they don't work on the Keo 2 max pedals. Thanks!
There are no new unread posts for this topic. Look pedal washers and Keo Blade 2
liam7020
Wed Jan 25, 2017 1:03 am
liam7020 View the latest post
There are no new unread posts for this topic. Negative GSL tuned brakes - use of padholder spacers and release lever
Slimtim
Tue Mar 21, 2017 2:45 am
KC View the latest post
Users browsing this forum: Baidu [Spider], benjaminm3, Bing [Bot], CBRE, chiumomo, Google [Bot], Google Adsense [Bot], kookie and 36 guests
