Bigger Rings for Campag Ultratorque Compact Chainset
stuarts
by stuarts
Guys,
I've just picked up a nice winter training bike, only problem is it being fitted with a compact chainset.
Does anyone know what's the biggest inner ring I can fit? Ideally I'd like to fit a 39 - not so worried about the 50 outer, it is a winter trainer (when I tend to use smaller gears anyway).
I'd prefer to just change the 34 ring if possible rather than mess around changing chainsets.
Cheers!
bontie
by bontie
http://www.campagnolo.com/repository/do ... -03-12.pdf
According to this no, but I am sure you could fit a 36 tooth, and these guys even offer a 38 tooth option.
http://www.sigmasport.co.uk/p/19529/ner ... leShopping
Blackwidow
by Blackwidow
My LBS mentioned Campag are coming out with a 52-36 combo for their compact crank. Just ask around and see when it's available in your part of the world...
"24/7 Im always in spandex, cut through the wind, cos Im aero-dy-na-mic"
http://www.youtube.com/watch?v=Vn29DvMITu4
ultimobici
by ultimobici
Miche do a range of rings to fit. Supertype for 11 & Compact for 10 speed. Condor in London have them.
natiedean24
by natiedean24
TA Specialites makes rings that may fit your bill. Check out the 'Nerius' and 'Nerius 11' range:
http://www.specialites-ta.com/gb/plateau-nerius11.html
c50jim
by c50jim
RIbble - www.ribblecycles.co.uk - has Stronglights in 38 in stock and they're in your neck of the woods so delivery should be quick.
You could always sell the compact crank and pick up a regular one if you really want the 39.
LionelB
by LionelB
50/39 works perfectly on a campa compact crank with TA or Stronglight rings.
mjduct
by mjduct
I have a standard Campy Record crankset (39/53) that I'd be happy to trade with you PM me if you are intersted
