ZIPP 404 clincher (aluminium body)
kavitator
by kavitator
maby there was a topic about that
Are they better than mavics Cosmic SL?
hubs durability? bearings? low stiffness (or it is just for 404 tubular version)?
thx
canbakay
by canbakay
yes, used both and 404s much better by all of those accounts. However, more expensive (tho there are some pretty good deals at the moment with the whole firecrest & CC range being the 'better' ones)
Neither are super stiff still, but the cosmics would swing like wind shield wipers under heavy stress...
kavitator
by kavitator
i had the opposite experience.
Maby zipp on my ride has loosen spokes
I race on cosmics sl for some time and they were stiff (until rim crack- i think spokes has too much tension after servis)
so zipp clinchers8alu rim) are stiff and durable?
PoorCyclist
by PoorCyclist
I ran the 2011 404 alum for few hundred miles they are pretty good. No problems so far, easy to install tires.
I feel they make the hub very light and not sure if this is a problem long term. My Shimano C50 is about 200g more, where did Zipp take the weight out? Hub, alum freehub body, and the carbon seems a bit thinner than Shimano. However the 188/88 hub is probably the best one they have made so far.
kavitator
by kavitator
thx!
:thumbup:
ave
by ave
My C50s is 1710g with base tape.
Zipp says 1662g for the 404 alu clinchers, my guess that's without tape.
Where does the 200g you mention come from?
PoorCyclist
by PoorCyclist
ave wrote:>My Shimano C50 is about 200g more, where did Zipp take the weight out?
RS-80 with a heavier hub (mainly steel freehub vs Ti) and wider spokes.
kavitator
by kavitator
zipp are really nice bulid. I got in hand 2012 series.
just spoke tension is little low
And intresting rear one has radial lacing on drive side , 1x on non drive side. :roll:
