Token TK520TBT Carbon Hubs - Anyone use?
addicted
by addicted
Anyone built a wheelset with these? What did you think of them? Reliable flanges? Bearings?
Thanks!
BmanX
by BmanX
I am looking at getting a pair of these as well. I have an older pair of AC sprint 350s where the rear hub is going and since AC does not support these older hubs I think I will replace them with the Token and also at the same time have them laced with Sapim CX-Rays.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
cep111
by cep111
I just bought a pair! With the Token TK 221 skewers. If they work out I'm buying 2 more sets. Using them for some 50mm 420 gram carbon clinchers. Next set will be used for some Hed Belgium C2 rims, then possibly some 38mm clinchers. The Tiramec bearings look like they could be useful as well. I think they are beautiful. Skewers just won a couple of design awards. Mine are in route and should land next week. They remind me a lot of the Mavic ES anniversary hubs. The flanges look extra wide and should be strong. Rear bearings are 4 - 6802's which are used by Zipp, and many others.
http://www.tokenproducts.com/index.php? ... 166&page=3" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.tokenproducts.com/index.php? ... 170&page=3" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SL58
by SL58
I installed couple of those wheels, they work just fine.
I have no idea about skewers but wouldn't hesitate.
gregalfa
by gregalfa
I got both wheels, tub and clincher built with this hub. Love it.
I just tried the skewer from the shop, it is very securely lock. Going to buy some. :o
The Great CarboniO
sugarkane
by sugarkane
I'm using the Tk2341 skewers..
Look great, work great and mine weigh in at 35g..
Those hubs do look nice.
cep111
by cep111
There here!! Came in under weight too, 195 rear, 73 front
Phill P
by Phill P
looks like they have tiny narrow flanges, and small axles (in the front at least)
195 for the rear is pretty good, but given how small the front hub is 73 is average.
Carbon center sections in the past have had alignment issues (because the flanges have to be bonded to the carbon tubes and set parallel to each other) and the bonded interface gives an extra opportunity for cracking. As I said *in the past* most manufactures would have learnt from these problems. Hopefully who ever makes these hubs for token doesn't have these issues.
cwdzoot
by cwdzoot
I have a pair of the Token C22 Clinchers, been riding them over a year now and really like them. The hubs are noticeably smooth and really roll fast. Thumbs up!
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
roca rule
by roca rule
Anybody knows where can I get then and how much will I expect to pay?
Sent from my PG86100 using Tapatalk
roca rule
by roca rule
Is that the UK Ebay?
No wonder I couldn't find them.
Thanks for the link. With a little bit more positive feed back I will give them a try you're my next build.
cep111
by cep111
[quote="Phill P"]looks like they have tiny narrow flanges, and small axles (in the front at least)
I can compare them to the American Classic RD205 and Micro 58, The rear flanges are a staggering 13mm wider in the back, Rear axel uses the same bearing as the Zipp 404's etc so I think it's gonna be fine. American Classic sure uses narrow flanges
The front flanges are exactly the same as the American classic, Except the front inner axel is quite a bit larger. 1mm larger bore and 3mm larger external bearing size.
