It is currently Thu Nov 23, 2017 8:04 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Mon Mar 19, 2012 6:22 pm
I've been using this http://alex.phred.org/stemchart/Default.aspx website to compare different stem angles to figure out how much difference there is between different stem angles/lengths. It seems to give pretty reasonable results but can anyone else speak to the accuracy of this model? For example, see my pic. Can I use a 6* stem + 10mm spacers to ditch the goofy cone spacer and 10* stem on my CAAD10 and still have the same bar position?
File comment: Example
SuperSix Record/Chorus 11
PostPosted: Mon Mar 19, 2012 7:36 pm
The formula is simple:
Drop = sin(angle) * Length
a 110mm stem at 6 degrees has sin(6) * 110 = 11.498
same at 10 degrees = 19.1
The difference is the height to add or remove.
Note that your bars will also move slightly reachwise because of the steerer angle when adding/removing spacers.
PostPosted: Mon Mar 19, 2012 7:49 pm
Yes, it a convenient and accurate stem calculator.
There are no new unread posts for this topic. Stem and Bar choices?
Boshk
7
698
Sat Oct 14, 2017 1:26 pm
syplam View the latest post
There are no new unread posts for this topic. Help me slam my stem
[ Go to page: 1 2 3 4 5 ]
Mep
71
6066
Thu Apr 06, 2017 8:49 pm
darnellrm View the latest post
There are no new unread posts for this topic. Attachment(s) Bontrager XXX Stem
benhama
9
1128
Wed Aug 30, 2017 9:55 am
benhama View the latest post
There are no new unread posts for this topic. Canyon Stem
chunboon
Wed Jul 19, 2017 7:04 pm
MayhemSWE View the latest post
There are no new unread posts for this topic. Integrated bar and stem!
MC356
15
3269
Sat Mar 25, 2017 8:40 pm
p3dalfaster View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, bikemaniack, Imaking20, Mtek, Slammed and 41 guests
