It is currently Fri Nov 24, 2017 6:52 am
Post new topic  Reply to topic  [ 128 posts ]  Go to page 1 2 3 4 59 Next
 Post subject: Lightweight Meilenstein
PostPosted: Thu Mar 08, 2012 6:05 pm
http://www.bikeradar.com/road/news/arti ... ers-33364/
So are Carbonsports indirectly admitting that heat build-up on Standard-C's is in fact a problem, or that the brake surfaces wear out? If not, 100g is a lot to add (10%) for a problem that doesnt need addressing.
Having a pair of Standard C's on order and expecting delivery within a week or so, you could say I have a vested interest.
PostPosted: Thu Mar 08, 2012 6:10 pm
Interesting...I've had zero problems with heat buildup on mine and I use them on some pretty long/steep descents. 7% for 11+ miles with peaks in the 10-12% are regular. Two years now and they're great. :noidea: My only real complaint is mounting a tire on them can be a process in pain and cursing.
Thing 1 & Thing 2 & Thing 3
PostPosted: Thu Mar 08, 2012 6:31 pm
! mounting a tire on them can be a process in pain and cursing.
Which tyre do you use? I mounted Continental GP4000S and was shocked how easy it was -- how could the tyre stay on the rim if there was no force necessary to get them on? The inner diameter of the tyre seems to be bigger than the outer diameter of the rim.
BTW: so far I don't have any problems wrt braking either; maybe those enhancements are for people who are closer to the weight limit?
PostPosted: Fri Mar 09, 2012 12:56 am
Interesting...I use Vittoria and they're not fun to mount. :noidea: Otherwise that's my only issue and I can certainly live with it.
Deleted quote. PP
PostPosted: Fri Mar 09, 2012 9:26 am
I have them for 2 years now too.
And ok it's not an all day wheelset.
But in combination with th eLightweigth brakepads, I haven't had any problems so for.
Brakepads are good, don't wear wvery much.
And I've done big mountain rides like L aMarmotte with them too.
PostPosted: Sat Mar 10, 2012 12:42 am
Tinker, Taylor, Tart
No issues with my Standard C's so far, but confidence-inspiring good sense upgrades can never be a bad thing for £3k+ wheels - I'd gladly swap mine for the 100g penalty of a better wheel.
PostPosted: Sat Mar 10, 2012 1:12 am
Maybe they should be called NotSoLightweights.
PostPosted: Sat Mar 10, 2012 9:56 am
more details on new techonolgy used in new wheels
in SLOVENIAN language ...i hope google trasnlate will do the job
http://kavitec.blogspot.com/2012/03/oci ... -tudi.html
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Sat Mar 10, 2012 12:42 pm
New technology is heavy
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Mon Mar 12, 2012 7:28 pm
Where can you buy Lightweights in the US? There aren't any "premium dealers" listed for the US on their website, and I haven't had luck searching on Google either.
PostPosted: Mon Mar 12, 2012 7:43 pm
go to the "contact" section on thier website and they have a U.S. VP. He responds to email pretty quickly and is VERY HELPFULL (he has been for me).
There dosen't seem to be any offical (LBS) dealers. They just seem to contact the LBS and work is out. (that is what I had to do, at least)
Good luck. :D
PostPosted: Mon Mar 12, 2012 8:00 pm
Wrench Science has them on their website. Be prepared to spend a huge amount of money...
BTW: when I searched for them, I found a few more dealers in the USA.
PostPosted: Mon Mar 12, 2012 11:02 pm
My only thought is that a set of Enve 45 clinchers with Tune 150 & 45 hubs & cx-ray spokes will run about.....
1290gm (amd maybe 1280 even) so.... I start to wonder...
Don't get me wrong, I think they are great wheels, but with some of their reparability and accessability issues adding weight is making them less of a "Lighweight" wheel. Which is thier main draw.
I know they are "great wheels" but thier name is Lightweight........
(and yes that is a pretty light clincher, but it isn't what is used to be, when I can get an enve set just about the same weight)
I'm not trying to be overly critical, I'm just putting their pros (weight, ride quality) along side thier cons(accessabiblity, and repairability....and yes thay can be repaired, but you will have to mail them somewhere and it will take some time..in the U.S. at least)
And don't get me wrong, I am planning on getting some Obermayers, soon. :D
(and I have to admit, that is a very light clincher for a wheelset that can carry a "clydesdale" rider...but with disc brakes all this will be "moot")(not that I like the idea of disc brakes either)
PostPosted: Mon Mar 12, 2012 11:12 pm
Your same argument could be applied to the tubulars as well. Similar or even heavier than a comparable set of Enve's laced up with a light hub. They may not be as stiff, so be it....they will likely be close to twice the cost.
PostPosted: Mon Mar 12, 2012 11:19 pm
Cyclelife USA in Washington, DC sells Carbonsports wheels and can get them.
Gramz
Failed Custom Bike
There are no new unread posts for this topic. Lightweight meilenstein. 16/20 or 20/20?
TurboTommy
7
487
Mon Oct 30, 2017 7:47 pm
kgt View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
21
1068
Fri Nov 10, 2017 12:01 am
glepore View the latest post
There are no new unread posts for this topic. Identifying a Lightweight Meilenstein Schwarz
nismosr
Tue Aug 01, 2017 4:55 pm
jinnie799 View the latest post
There are no new unread posts for this topic. LW MEILENSTEIN CLINCHER - TUBELESS?
rafaelblu
Mon Jan 09, 2017 8:01 pm
rafaelblu View the latest post
There are no new unread posts for this topic. These Lightweight brakes?
PLuKE
7
1198
Mon Aug 07, 2017 8:42 pm
kulivontot View the latest post
Users browsing this forum: beeatnik, Bing [Bot], jlok, sarion, sib and 40 guests
