It is currently Sat Dec 16, 2017 1:07 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Tue Mar 06, 2012 11:06 pm
Every single rear flashing light I've bought, has ultimately died after a 6 months or so of riding in wet conditions.
Eventually water gets inside, and the light either fails, or needs to be taken apart and batteries taken out for it to be turned off. I've lost track of how many different brands I've tried.
Does any one have some good recommendations? I'm purely looking for something that handles months and months of wet conditions.
Thanks.
PostPosted: Wed Mar 07, 2012 1:10 am
Before we offer suggestions, which ones have you tried and have failed you?
PostPosted: Wed Mar 07, 2012 2:16 am
I've been using a Smart Lunar, Cateye TL-LD1100 and a Blackburn Mars 4 in all conditions for the last few years. All still going strong.
PostPosted: Wed Mar 07, 2012 5:18 am
I've gone through 2 Planet bike Superflashes, both ending up where i have to pull the batteries out to turn it off, then ultimately dieing:
Also various Knog lighs such as this one, Gecko I think (they all look cool, but are horrible in the wet):
Had a Cateye that looked like this fail too:
I've been tempted by a Smart Lunch rear light, but they look exactly the same as the superflashes, and I've read about a number of people having them fail in a lot of wet riding.
PostPosted: Wed Mar 07, 2012 5:35 am
Wow, you are hard on lights. I really like the Planet Bike lights, which seem to have failed you too. But I use it for the occasions when I might get caught in the dark versus day in day out riding in the cold and wet. I wonder, might it be from condensation which occurs if you come in from a cold wet ride then store your bike in a warm room? Just a thought. Don't know.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Wed Mar 07, 2012 6:51 am
I like the planet bike flashers too, and for the most part they have lasted for quite a few months. But when i do a few back to back rides in the wet, over a week or two they always seem to start failing.
I have read that opening them up, then putting a bit of vaseline on the seal can help. Haven't tried that as of yet.
PostPosted: Wed Mar 07, 2012 7:13 am
Current favourite and ridden in much, much wet weather:
Knog Boomer USB
USB Chargeable, no batteries to deal with.
PostPosted: Wed Mar 07, 2012 7:22 am
I have had good luck with the planet bike lights. I take them apart and put some grease in between the two halves and that solves any water issue. Had the same light for 3 years and it has been through a good bit of water.
PostPosted: Wed Mar 07, 2012 6:15 pm
Light and motion seems to make the most water resistant lights out there.
http://www.bikelights.com/vis180.html
I'd recommend going w/ a rechargeable light since one would have higher build quality.
PostPosted: Thu Mar 08, 2012 5:16 pm
http://www.exposurelights.com/product/000059/flare/
Batteries best bought online as hard to source in shops.
PostPosted: Sun Mar 11, 2012 2:57 am
Shop Wrench
I'm a fan of the princeton tec swerve. If I know I'm going to be out for hours in driving rain, I will put it on for added visibility, like a racecar rain light. Never had any problems and I have a few for my different bikes.
PostPosted: Sun Mar 11, 2012 9:16 pm
knog 3led - tip to improve longevity - if you've been out in the wet, open it up, remove batteries & let the electronic board dry out.
The panel is essentially open to water at the point where the led goes thru the outer casing, so once its gotten wet, the board & contacts will rust unless given a chance to try out.
OP - are you using lights with mud guards or without ? I tend to have more problems when the lights are in direct contact with water coming off the wheels. Add in a mud guard & there is less driving water hitting the light so longevity improves.
PostPosted: Fri Apr 06, 2012 8:10 am
why don't you use a rear fender :?: the light and your shorts stay dry.... :D
PostPosted: Tue Apr 10, 2012 12:41 am
I would use standard silicon brake lube instead of vaseline. Vaseline will eventually deteriorate the rubber. Silicon lube is good for the battery cover too. You can pick it up at any auto parts store in small packets.
PostPosted: Wed Apr 11, 2012 9:26 am
I use this light off Knog: http://www.knog.com.au/gear-lights/boomer-rechargeable.phps with rain i use a sandwichbag where i put the lights in, perfect. Use it for a year in very wet conditions!!
There are no new unread posts for this topic. Daytime Rear Light Recommendation
MRM
43
3448
Tue May 23, 2017 4:41 pm
Calnago View the latest post
There are no new unread posts for this topic. Light rider, need light wheels, light wallet?
in Everything wheels
eyedrop
Fri Mar 03, 2017 10:28 am
Multebear View the latest post
There are no new unread posts for this topic. REAR HUB ZIPP 188
nick007
Thu Aug 24, 2017 9:20 am
kavitator View the latest post
There are no new unread posts for this topic. Campag SR rear mech
Timujin
Fri Apr 28, 2017 8:40 pm
mattr View the latest post
There are no new unread posts for this topic. Clutched rear derailleur 2x
jfranci3
15
1046
Fri Aug 11, 2017 2:56 pm
wheelsONfire View the latest post
Users browsing this forum: No registered users and 4 guests
