It is currently Tue Jan 23, 2018 4:56 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Remove carbon paint
PostPosted: Wed Feb 29, 2012 5:28 am
I would like to remove some carbon paint on my seatpost.
Any idea other than carbo-lift ? I cant get this in my country and their online purchase link seems not working.
Thanks
Passoni Mirror
Passoni Xxti
 Post subject: Re: Remove carbon paint
PostPosted: Wed Feb 29, 2012 6:10 am
This has been covered alot here- use the :search:
But to get you started-
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=79102
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=83500
PostPosted: Wed Feb 29, 2012 7:15 am
I know sanding is the best option, but is that safe to do it on the seatpost ? i need to blackout the wording, its been spray by the previous owner and i dont want to scratch that clear coat.
Passoni Mirror
Passoni Xxti
PostPosted: Wed Feb 29, 2012 8:16 am
Administrator
That seat post is not painted. The surface layer is epoxy.
Sent from my HTC.
{USERNAME} wrote:
PostPosted: Wed Feb 29, 2012 8:19 am
Sent from my HTC.
so what should i do now? is epoxy more worst than paint ? :noidea:
Passoni Mirror
Passoni Xxti
PostPosted: Wed Feb 29, 2012 2:21 pm
Administrator
Why would you want to remove it?
Sent from my HTC.
PostPosted: Wed Feb 29, 2012 3:15 pm
Hi, just use some 600 grit wet and dry adbrasive paper then finish with 800 grit.
You can just leave just like that or get a car bodyshop to put some 2k clear top coat on it.
If you cannot find wet and dry then scotchbrite pads will do the same job.
good luck. :beerchug:
PostPosted: Wed Feb 29, 2012 3:36 pm
Sent from my HTC.
Just too many wording there. my whole bike are nude blackout type, it looks too busy on the seatpost.
Passoni Mirror
Passoni Xxti
PostPosted: Wed Feb 29, 2012 3:39 pm
will it scratch the clearcoat ? i afraid after i send the wording part, the part will become white.
i have a very fine 3000 grid,can i use that?
Passoni Mirror
Passoni Xxti
PostPosted: Wed Feb 29, 2012 5:23 pm
I sanded my token seatpost. Got the decals off without touching the clearcoat ,I wet sanded it. In the end I sanded the clear off and used some 303 aero , It looks much better than the clear coat.
PostPosted: Thu Mar 01, 2012 2:36 am
Just to update, i managed to use a blade cutter to shave the wording off with less scratches.will sand it after i am done. :thumbup:
Passoni Mirror
Passoni Xxti
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. Any easy way to remove white logos on carbon rims?
Shrike
Sat Jan 28, 2017 12:11 am
Broady View the latest post
There are no new unread posts for this topic. Paint or Carbon crack? - Canyon Ultimate CF SLX
hypercycler
12
1574
Mon Oct 23, 2017 7:18 pm
topflightpro View the latest post
There are no new unread posts for this topic. Attachment(s) Paint Crack or Carbon Crack
ALAN Carbon+
27
3438
Sun Sep 17, 2017 8:23 am
micky View the latest post
There are no new unread posts for this topic. Attachment(s) How to remove second bolt on Sram (Red) Chaingrings
jbattermann
Tue Aug 01, 2017 10:43 pm
jbattermann View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], leej88, maverick_1, pdlpsher1, spdntrxi, toshi and 39 guests
