Post new topic Reply to topic  [ 30 posts ]
Go to page Previous  1, 2
 Post subject: Re: rollerracing.ca
PostPosted: Sat Feb 25, 2012 5:36 pm
Hi
Some more info http://blog.rollerracing.ca.
We also have a Twitter account: @rollerracing
Thanks!
J
Race your bike in realtime using your browser
http://www.rollerracing.ca
PostPosted: Sat Feb 25, 2012 7:20 pm
Very cool - very excited to try it out.
PostPosted: Wed Feb 29, 2012 8:21 pm
Can't sign up at this time but I did provide my email. I use Trainer Road and like it quite a lot so this seems interesting.
PostPosted: Mon Apr 02, 2012 8:54 pm
B B B B Bump.
Any News. Has the weather in Canada improved enough to shelve the project till next winter? Just wondering because the weather here went from 20 degrees C three days ago to snow today.
PostPosted: Mon Apr 02, 2012 8:58 pm
Mikeno wrote:
B B B B Bump.
We are still working on it. ;-)
We hired two new developers and have started to migrate to new servers.. So invites are coming!
J
PostPosted: Tue Jan 08, 2013 2:08 am
Hi everyone
We are now in full beta mode and we are accepting new accounts to be a beta tester.
Sign up here: http://www.rollerracing.ca and you can race anyone over the web in realtime using nothing but a ANT+ stick, (USB2 and USB1) a power meter OR a speed sensor and a fluid trainer and your browser. We supply everything else.
We will start organizing weekly races soon where you can win a Roller Racing t-shirt.
I hope to race you soon.
Thanks
J
PostPosted: Tue Jan 08, 2013 6:38 am
Can you draft off someone then launch for a sprint off of them?
Exp001
PostPosted: Tue Jan 08, 2013 12:00 pm
2 questions:
1) can i play on a set of ordinary rollers? if not, why not? anything i can do to change that (short of buying a compatible fluid trainer).
2) which ant stick do you recommend?
PostPosted: Tue Jan 08, 2013 3:51 pm
When we first started working on Roller Racing, we did a survey: viewtopic.php?f=14&t=92343
The results (which have been since clobbered, but I can find them if you like) showed that fluid trainers were the most popular.. Computrainer did rather well in the poll as well.
So we focused our energies on the main fluid trainers.
Also, fluid trainers are the easiest to produce a speed -> watts algorithm because the curve is always the same..
This is also true for rollers but the problem with rollers is that there are so many of them and they all have different power curves. Some even have resistance on them which complicates things even further.. But this isn't to say we won't support rollers, the question is, which ones ?
I hope that helps.
As for which ANT stick, I would just get the Garmin USB2 ANT stick. Drop me a PM and I can tell you the best places to go to get one.
J
PostPosted: Tue Jan 08, 2013 11:13 pm
does the type of trainer used still matter if you have both a powermeter and a speed sensor?
at a guess, i would think that trying to support rollers would be a pretty tough affair - speed VS power relations vary greatly due to variables like bearing condition, tyre pressure, etc...
PostPosted: Tue Jan 08, 2013 11:45 pm
If you have a power meter, you can use any trainer you want with any resistance..
If you do not own a power meter but you do own an ANT+ speed sensor, we try to simulate watts based off your speed and off the trainer you are using. This is why knowing the trainer is important when using a speed sensor only.
If you own a power meter, all you need is a power meter and any trainer you wish to train on.
I hope that helps!
J
PostPosted: Thu Jan 24, 2013 4:49 am
only input your e mail ....?? have to wait for the confirmation....
PostPosted: Thu Jan 24, 2013 2:23 pm
If you signed up, expect a confirmation code to sign up before this weekend.
Thanks for trying !
J
PostPosted: Thu Jan 24, 2013 5:10 pm
Power2Max aren't listed in your compatable powermeters. They use ANT+. Are they compatable?
PostPosted: Thu Jan 24, 2013 6:02 pm
If it works with a Garmin 500, it will work with Roller Racing.
J
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
Users browsing this forum: No registered users and 2 guests
It is currently Fri May 24, 2013 2:04 am
