Post new topic Reply to topic  [ 16 posts ]
Go to page 1, 2  Next
PostPosted: Wed Dec 28, 2011 5:55 pm
I’m a guy that came down with prostatitis about a year ago and had to be off the bike the entire time to heal. Now I really want to ride again but can't sit on saddles with noses as well as unconventional “anatomic” saddles like Selle SMP, Adamo, etc. since major irriation comes back. I’ve been forced to use a noseless saddle on my Colnago and it works OK but with a much more upright body position.
I would like to know if anyone can recommend a wider and harder saddle that has a flatter profile and a relief groove. Maybe something made of carbon that is 160mm in width. This should support my sit bones better than the thinner saddles.
Ps. Yes, I have had several professional bike fits and still have the issue.
PostPosted: Wed Dec 28, 2011 6:55 pm
While not 160 mm wide, have you seen the San Marco Mantra saddle?
That thing has a veritible (someone coined it here a while back) "scrotal valley."
Note: the Carbon FX version of the Mantra is slightly narrower, so the standard version is what you should review (144mm).
Another consideration is a custom saddle...
Out of curiosity, and not being a doctor, have you considered bibs/chamois choice in addressing this ailment?
PostPosted: Wed Dec 28, 2011 7:31 pm
My issue revolves around the ability for a saddle to support my sitbones and since I have wider sit bones, I need a wider saddle for more support.
PostPosted: Wed Dec 28, 2011 10:04 pm
This might work for you: http://www.ismseat.com/saddles/adamo-breakaway
Here's the weightweenie version: viewtopic.php?f=3&t=90527
I use the Adamo Podium (same as Breakaway but with less padding) on my road bike and have no problem racing it successfully (in agressive sprints that require good handling - it's not just for TT'ing). I've tried most other cut-out saddles including the Mantra, and the cut-outs just aren't wide enough for me. For me, the Mantra pinches in the front, and the SMP saddles are too curved (banana-shaped) with sharp edges that are pressure points. The Adamo is the only one I can tolerate.
Bottom line: The only way completely eliminate perineal and prostate pressure is to completely remove that part of the saddle. Pressure needs to be distributed to the bones (ischial tuberosity) which may require a short period of adaptation - especially if you've been sitting on your soft tissue for years.
PostPosted: Thu Dec 29, 2011 1:48 am
Take a look at the Specialized toupe 155mm. Its a flat saddle. Speccialized may have a 165 on the way but I would give the toupe a go. good luck let us know what you find and works.
PostPosted: Thu Dec 29, 2011 4:34 am
Thanks for all the great suggestions but I have already tried the ISM Adamo, Selle SMP Plus, Specialized Toupe and they were all too narrow and did not support my sit bones. I guess I'm just going to have to see if they ever come up with a wider platform in one of those road-type saddles.
PostPosted: Thu Dec 29, 2011 8:42 pm
What about this?: http://www.ismseat.com/saddles/ism-sport
Here are some saddles that are more than 150mm wide: http://www.wekeepyoucycling.com/en/c-34-width-150.aspx
If you're really desperate you can just pick a saddle with edges that you like, saw it down the middle, widen it by pushing it apart on the rails with a brace then reupholster.
PostPosted: Sat Dec 31, 2011 11:04 pm
I had some prostatitis issues in the past and have found the Mantra to work well.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sun Jan 01, 2012 9:35 pm
Selle Italia slr superflow and the new for 2012 max slr gel flow are worth a look.
PostPosted: Sun Jan 01, 2012 11:40 pm
Tip the nose of your saddle down slightly like how women ride and try it. More pressure on you hands less on your stuff.
PostPosted: Mon Jan 23, 2012 2:37 am
While not totally flat, the Specialized Romin Evo is a nice saddle for sitting directly on the sit bones. They make a 155 mm wide model too.
I've not tried them, but the Dash saddles might fit your criteria. Not cheap but they have a demo. http://www.dashcycles.com/products/
I've been fighting with a similar issue combined with some back issues. It's been tough trying to transition saddles from the saddle I've used for the past 2 years.
Good luck!
PostPosted: Tue Jan 31, 2012 11:57 pm
Good luck!
Man does it ever make you sit on those bones too. Zero pressure on my taint at all, but it absolutely killed my sit bones, maybe a good choice for the op.
PostPosted: Thu Feb 02, 2012 4:30 am
have you tried brooks saddle? maybe a b17 imperial
PostPosted: Fri Feb 03, 2012 7:24 pm
Regarding the Romin Evo... I had some more time on it and have decided that my "undercarriage" prefers a more flat saddle. When I tilt my pelvis forward, it puts even more pressure on my perineum due to the curvature of the saddle. I'm back to the Arione, but have an SSM Regale on the way.
PostPosted: Tue Feb 07, 2012 5:48 pm
Did you try an Arione Versus with the cutout to get rid of perineum pressure?
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Right Leg brushing saddle? Fit Question
[ Go to page: 1, 2, 3, 4 ]
SolidSnake03
53
2400
Sat Aug 18, 2012 2:45 am
SolidSnake03 View the latest post
There are no new unread posts for this topic. Saddle Fitment Question
addictR1
Thu May 16, 2013 5:45 am
addictR1 View the latest post
There are no new unread posts for this topic. Looking for a new saddle - question about width??
G6612
Sun Jan 27, 2013 2:02 am
AGW View the latest post
There are no new unread posts for this topic. Bike fit question - saddle set back and stem length
Tubby531
10
677
Mon Jan 28, 2013 12:10 am
neeb View the latest post
There are no new unread posts for this topic. need saddle help.
Elrey
11
490
Tue Nov 06, 2012 3:12 pm
Juggler View the latest post
It is currently Sat May 25, 2013 12:55 am
