It is currently Sun Feb 26, 2017 2:52 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Tue Nov 08, 2011 2:20 pm
Hi All
My power tap was inactive for a couple of months but when i use it now its only reading Hr and speed no cadenmce or power. When i was last using it i had it on my TT bike with the sensor for speed only. I think i changed the settings so it would not be "looking" for the hub.
Could anyone tell me what i did and what setting i have to change to get it back working with power?
Thanks a mill
John
PostPosted: Thu Nov 17, 2011 2:10 pm
under setup > look for sensors > rotate wheel at axle (assumign powertap) > pair with sensor >> anything show up?
sounds more like a hub problem to me.
make sure batteries in your watt meter (powertap) are charged
Next try reseting joule whilst connected to poweragent
Next try pairing joule with someone else's equipment.....next try (if you can) someone else's powermeter (doesnt have to be a joule)
Next, but not to be taken lightly...If all else fails it is possible to completely wipe the joule and start again. To do this you format the contents of the joule folders on the computer (obviously this wipes past data on the joule but uploaded data ok, and the config files). unplug and replug the joule, it then reboots with the correct new software and start from stratch.
There are no new unread posts for this topic. Power on the Trainer - how can you use it?
in Training
AJS914
Wed Jan 04, 2017 3:40 pm
GothicCastle View the latest post
There are no new unread posts for this topic. Colnago EPS or Extreme Power
in Wanted
KWalker
Mon Jan 16, 2017 4:50 am
KWalker View the latest post
There are no new unread posts for this topic. Shimano 105 Power Meter
lwrncc
Fri Jul 01, 2016 7:31 pm
2lo8 View the latest post
There are no new unread posts for this topic. Need some power meter advice
jeroenDG
10
803
Fri Aug 12, 2016 4:37 pm
Briscoelab View the latest post
Users browsing this forum: Bing [Bot], latsride and 1 guest
cron
