Powerprofiles
Sandal
by Sandal
guys, is 20.14W/kg at 1 sec power something very unique? Does is mean you're born to be a sprinter?
weight concerned = good, weight obsessed = bad!
hna
by hna
Depends on your bodyweight. And what is your 5 sec and 15 sec wattages? They are much more important than the 1 sec.
Sandal
by Sandal
i won't be able to try it for another 2 month probably as the true winter has finally begun where i live. Do you mean there is no direct corelation b/w 1sec power with 5 and 15 sec power?
The weight is 74kg now during off-season. i'll get rid of 2-3 kgs around the waist :) closer to the season.
hna
by hna
You don't win races with 1 second efforts. Not 5 sec either, but it gives a pointer towards acceleration. 15 seconds is a more typical sprint scenario.
And a complete overview of the sprint durations gives a better picture than just one number.
Edit: Your sprint isn't bad, but it doesn't necessarily make you a sprinter. You have to look at the even bigger picture to see that (5 min, 20 min and 60 min wattages). And even then it's not set in stone.
hna
by hna
While I am here I might as well post my own numbers:
5s - 1205 W
1 min - 721 W
5 min - 397 W
20 min - 340 W
60 min - 320-ish (estimation)
Weight: 64-65 kg
The 1 min value is good. The rest are allright. All from last season.
Tapeworm
by Tapeworm
Sandal wrote:guys, is 20.14W/kg at 1 sec power something very unique? Does is mean you're born to be a sprinter?
FWIW 20w/kg for 5 sec is the bottom rung for track sprinters, top rung for roadies. But as mentioned it's a bit of a pointless metric unless you have the engine to get to the end to use it. And even then sprint usually draw out longer than 5 sec.
"Physiology is all just propaganda and lies... all waiting to be disproven by the next study."
"I'm not a real doctor; But I am a real worm; I am an actual worm." - TMBG
RyanH
by RyanH
Here's my stats for the last 6 weeks:
5s 17.2w/kg
1m 9.3w/kg
5m 5.6w/kg
20m 4.9w/kg
Racing as a Cat 4 in SoCal. It's my 3rd year racing and riding. I was competitive last year, with a lower absolute power profile and 10lbs heavier.
I'm a lot stronger this season so hoping there will be an upgrade in the near future; however, everyone seems overly strong this season based on last week's race.
Are these decent numbers for Cat 4/3? Seems there are a lot of big numbers in this thread.
Strava
nathanong87
Resident master of GIF
by nathanong87
to answer your question. 'yes'.
Tinea Pedis
by Tinea Pedis
You should be Cat'ing up to 3 with those numbers.
KWalker
by KWalker
Numbers don't win races so don't worry about it. Race smart and you'll be fine.
Remember that almost none of the claims in this thread are actually verified by anything.
Gramz
Failed Custom Bike
paddydog
by paddydog
"And even then sprint usually draw out longer than 5 sec."
Tape = a genius.
JamieL
by JamieL
I've found that for sprints (and for almost all the flat racing i do in the ME) it's absolute power much more than W/kg which matter.
5s: 17.5W/Kg
1min: 12W/Kg
5min: 6.6W/Kg
20min: 5.5W/kg
But i weigh 62Kg so i struggle to get away on the flat and i can't get near the front on a sprint - So as KWalker says; Got to race smart.
KWalker
by KWalker
5.5w/kg would put you well near the front in lots of cat 1 and domestic pro crits in the US. A teammate of mine has several top 20 NRC finishes and weighs exactly the same with a similar 20min output. Your 1min is also more than adequate for even a world tour rider, so its somewhat surprising to hear that you have issues.
Gramz
Failed Custom Bike
indigo
by indigo
So many good numbers, this is dispiriting.
Can anyone post stories of having had a 190w FTP who now puts out 400+ ??
Or describe when you have had your biggest gains, and what they were.
I have a torn meniscus and am feeling miserable :-( Now unable to train for a while.
Tinea Pedis
by Tinea Pedis
I don't think I was at 190, but was once a full on Hubbard. Wore pro replica kit and all.
What would you like to know?
