It is currently Thu Mar 23, 2017 11:37 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: Watt power should I use?
PostPosted: Mon Oct 31, 2011 3:37 pm
Im planning on using power in my winter training for the next road season. But am at a loss of which way to go in latest raft of new powermetering systems. Any recommendations or opinons?
PostPosted: Mon Oct 31, 2011 5:47 pm
I'm sure there will be different opinions as to what system is best, but personally, I am currently batting for Powertap.
We've been doing loads of research here with regards to the release of the 2012 range (which is now available to purchase), and I think on balance Powertap is the best system for most people.
It is more flexible (transfers to bikes easily) and cheaper than say SRM, Polar, Garmin and Quarq etc. Whats not to love?
Well, bearing challenges are the main one, plus there is the thorny issue of training/racing wheels and whether you want to be training on 50mm carbon rims, or racing on a 32hole trainign wheel! I think this is some of the thinking behind the 2012 Powertap range... there are only two options now, the 2012 Pro and the G3 hubs. The G2 is race orientated, the pro the cheapest hub Powertap have ever produced. You can have one of each, plus a head unit, and still have change from the cost of a set of Quarq.
My website has a little article on the 2012 range. http://www.koolstofcoaching.com/article ... and-wheels
As mentioned, I am sure others will have different opinions. I 'd really like to hear from people that have got their hands on the new pedal based systems.
www.koolstofcoaching.com - where cycling dreams come true... sometimes!
PostPosted: Mon Oct 31, 2011 6:18 pm
I got a quarq after having to send in my PT SL+ 2 times and my SLC+ in once. The turn around in Canada was 3 weeks. The third time I sent it in I drove across the boarder so Saris would accept it, even though I bought it from the US.
Can you calibrate the new PT hub or do you have to send it in like the old one?
PostPosted: Tue Nov 01, 2011 1:10 pm
For it's proven reliability and results alone I always recommend the SRM. I have been on SRM for over 10 years and my original system (PowerMeter and PowerController) are still going strong. The newest system is very good (I am currently using a DA7950 SRM with an alloy-cased PC7). I would recommend a used, wired SRM, which is about bomb-proof as you can get.
PostPosted: Tue Nov 01, 2011 1:42 pm
i am using powertap and power2max. both reliable, beneficial systems, delivering accurate values (i validated the p2max with my powertap).
maybe it would make sense to consider, if you want to use different bikes with the pm, or use a pm-equipped bike with different wheelsets.
edit: pedal-based system could be really convinient. but i fear, bringing it to market takes to long for a use already in the winter-training.
sorry vor mai bed englisch!
PostPosted: Tue Nov 01, 2011 8:32 pm
I have a PowerTap, but if I were to be buying a PM now I'd probably go for a Power2max. The PowerTap is very restrictive when it comes to wheel choice and racing with the PM provides really useful information. My current approach is to build the PowerTap into a carbon rim for the summer and use that for training and racing, and then switch to an alloy rim for the winter to train with. Not ideal, but it works.
As for ease of switching - I think you'll probably find that switching cranks will be as quick if not quicker than switching pedals so I'm not sure the pedal-based systems are really much better in that regard. And it looks like they'll cost at least as much as the Power2max anyway.
PostPosted: Fri Nov 04, 2011 12:57 am
SRM if you got the cash. Second place on my books go to Powertap. I had two powertaps, but sold one and was planning on selling my 24h as well and upgrading to SRM...but...SRM at $2700 for the powermeter, is lots of money. I might actually get another Powertap again.
That Power2Max looks good though especially at that price as long as it works as promised.
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
PostPosted: Fri Nov 04, 2011 7:51 am
I use the Power2Max and works as advertised :D
PostPosted: Thu Nov 17, 2011 2:16 pm
surely garmin vector pedal power is the one to get (from mar12)....its £1149 in the UK, gives pedal balance, ANT+. I am saying that as a regular powertap user. I'd recommend the joule head unit which is awesome provided you don't need GPS. Vector will transfer between bikes better than anything else....nb look keopower not ant+
PostPosted: Thu Nov 17, 2011 3:38 pm
What makes the Vector better than the Power2max? Easier to move between bikes? Nope. Cheaper? Nope. Both ANT+? Yep. The L-R balance is a gimmick as far as I can tell.
Power2max actually works as well :wink:
PostPosted: Thu Nov 17, 2011 10:26 pm
Slightly off topic, but I am looking at wired SRM units as they go for ~£400 for the whole caboodle.
Could someone please tell me what heart rate monitor(s) are compatible with the PowerControl V?
PostPosted: Fri Nov 18, 2011 3:04 pm
Polar.
PostPosted: Fri Nov 18, 2011 3:09 pm
Thanks
PostPosted: Fri Nov 18, 2011 10:23 pm
you can use one set both on road and MTB bikes
weight concerned = good, weight obsessed = bad!
PostPosted: Sat Nov 19, 2011 11:13 am
+1 for the Power2max system. Simple to fit and use, accurate when run against Quarq/SRM and at their price, really fits the bill.
There are no new unread posts for this topic. Power on the Trainer - how can you use it?
in Training
AJS914
Wed Jan 04, 2017 3:40 pm
GothicCastle View the latest post
There are no new unread posts for this topic. Power meter crazies, what do you say?
wheelsONfire
Mon Mar 28, 2016 11:57 am
wheelsONfire View the latest post
There are no new unread posts for this topic. Need some power meter advice
jeroenDG
10
847
Fri Aug 12, 2016 4:37 pm
Briscoelab View the latest post
There are no new unread posts for this topic. Less laggy power meters
warx
28
2526
Sat Sep 17, 2016 12:39 am
chipomarc View the latest post
Users browsing this forum: No registered users and 1 guest
