Post new topic Reply to topic  [ 12 posts ]
 Post subject: training ?
PostPosted: Tue Oct 04, 2005 6:22 am
I am a 35 year old ex-mountain biker. I want to enter a few cross and road races next year and would like to do ok in my age group locally.
My max hr I have recorded on my polar in the last year is 186.
About 4 times a week I try to stay between 170 and 180 for 1 hour and maybe at 150 to 160 for another hour. Due to crappy weather I often run on the treadmill. This has helped me, but obviously it is a simple plan.
Ocasionally I'll throw in a century or a long ride with the guys in the fall/winter and replace the tradmill with the bike in decent weather. I regularly get my ass handed to be on hills all sumer. On the flats I can hold the mid 20s(mph).
I try to limit my fat intake. I am 5'10" and 165lbs.
Any simple advice for me?
 Post subject:
PostPosted: Tue Oct 04, 2005 9:26 am
without trying to be a smartarse or anything, there's too much to tell you here...
simple advice - structure your training and stick to it
even simpler - get a good book which can give you some direction, including a scientific basis to your training as opposed to listening to all the "experts" on the internet
good luck!
 Post subject:
PostPosted: Tue Oct 04, 2005 10:30 am
HR's change according to exercise.
"Ride it like you've just stolen it!"
 Post subject:
PostPosted: Tue Oct 04, 2005 11:01 am
HR changes according to hydration status
HR changes according to age
HR changes according to altitude
HR changes according to fatigue levels
HR changes according to gender
HR changes according to ambient temperature
we could be here forever - get some references and some resources and educate yourself... :wink: some awesome books out there
 Post subject: Re: training ?
PostPosted: Tue Oct 04, 2005 6:20 pm
While the above comments are all correct, there is one application where a HRM is of considerable use: indoor training. Here, conditions are stable and with proper cooling heart rate provides an excellent measurement of relative exercise intensity. In the winter, most of my training is indoors over a narrow HR band (85%-90% of max) in 45 minute and 60 minute blocks (spin classes), day in and day out. This is very, very effective at both raising functional threshold power and keeping the pounds off, as you are working very hard but not overstressing the system -- unless the room is too hot. It is also the modern idea of “base” training.
John979
PostPosted: Tue Oct 04, 2005 8:47 pm
John979 wrote:
In the winter, most of my training is indoors over a narrow HR band (85%-90% of max) in 45 minute and 60 minute blocks (spin classes), day in and day out....It is also the modern idea of “base” training.
Really? Not from my last coach, who is one of the big proponents of "modern" training methods. That's way too high for base training. He used to flog me when I tried to tell him I was riding easy and then he'd see my power readings and know I was pushing harder than he wanted me to.
Put it this way, during my later base period, he wanted me riding under 160bpms. Given my ~ 200bpm max, that's <80%. during the early base, he had me riding at < 150 (75%)!
PostPosted: Wed Oct 05, 2005 6:07 pm
Not surprised here. Dr. Lim was recently trashed in another forum by a couple so called "modern' trainers on this subject and related aspects of overtraining. However, I stand by my statement which is backed by some interesting work by Dr. Coggan as well. This approach (keep intensity high, modulate volume) is of particular importance to those who have limited schedules or where weather conditions prohibit outdoor training. From another point of perspective, if all you have is an hour and don’t work at least moderately hard, you are detraining.
John979
 Post subject:
PostPosted: Thu Oct 06, 2005 5:11 am
yeah that sounds way, way too high for base training to me as well. once you're hitting 90% max HR you're close to, if not already in your anaerobic zone
John - do you have the name of the studies Dr. Croggan? would be interesting to read them.
cheers
 Post subject:
PostPosted: Thu Oct 06, 2005 3:38 pm
cheers
For me, maintaining an effort at 90% max heart rate for 45 minutes is not difficult and is completely aerobic. It takes some concentration but the real issue when training at this level indoors is cooling. In addition, many find this type of workout difficult more due to technique than ability: trying to get to the target heart rate level too fast. I have an isopower data file of a very hard effort under perfect (cool) conditions: for one hour the power is essentially constant at my max hour power, but my heart rate did not hit 90% until 25 minutes into the race (a hillclimb). Here, my average heart rate for 59 minutes was 89% of max. The key then is using HR as a guide is to ramp up slowly.
If you want more information on this topic, go to the Topica wattage forum and do a search on “sweet spot.”
PS Aerobic/Anaerobic are other terms, like LT I try to avoid, just like "oxygen debt" because historical they have been misused. Simply because one exceeds "LT" does not mean one has switched to anaerobic mechanisms. For example, even the 4 K pursuit, an all-out effort of 4 minutes, is largely aerobic, with the anaerobic component only at the start.
John979
 Post subject:
PostPosted: Fri Oct 07, 2005 12:09 pm
fair point - mind you working at 90% of max HR is working at 80% Vo2 max, equivalent to 70% of peak power output - so it's not a huge intensity...
you're right - terms like LT are confusing as they are horrendously misused. I also do agree that if you do cross your AT (the hypothetical 4mmol or thereabouts level) you do not necessarily go anaerobic though that does depend on how well trained you are...
we could go on here forever discussing it!
 Post subject:
PostPosted: Fri Oct 07, 2005 2:06 pm
From a power perspective, your numbers are dead on and demonstrate the value of looking at things from the power perspective.
Interestingly, this approach to training also seems to maintain/train maximal aerobic power without intervals. Very curious. However, in order to peak your functional threshold power, you need to really push very hard in the L4 zone, something I avoid until necessary. Low level 4, as you agree, is not hard to maintain; high level 4, and the difference is not much, is very taxing.
John979
PostPosted: Thu Oct 20, 2005 6:14 am
All this argument over LT, power, ect is great for coaches and knowlegable athletes, but it doesn't help me.
I am hoping that someone can say, excersize at 90% of your HR 4 times a week for an hour and a half at a time or something practicle like that for cross racing.
I can post my hr records to show what I have been doing if that would help.
Users browsing this forum: Google [Bot] and 8 guests
There are no new unread posts for this topic. US Training camps?
in Training
AttacknowAttackoften
Mon Dec 24, 2012 10:39 am
kiserkm View the latest post
There are no new unread posts for this topic. Training or Nutrition?
in Training
mellowJohnny
21
1953
Tue Oct 23, 2012 9:55 am
JMT View the latest post
This topic is locked, you cannot edit posts or make further replies. Training plan
in Training
razer1
Fri Jun 22, 2012 11:27 am
razer1 View the latest post
There are no new unread posts for this topic. Help with tweaking my training
in Training
welkman
20
1709
Sat Feb 23, 2013 2:20 pm
welkman View the latest post
There are no new unread posts for this topic. Threshold training
in Training
drhule23
Wed Dec 12, 2012 5:33 pm
erty65 View the latest post
It is currently Sat May 25, 2013 9:18 pm
