Kind of a vulgar question about bicycle fitting
phourgenres
by phourgenres
When we are doing a general fitting for a bicycle, and we are trying to get 1 to 2" inches of clearance over our standover height, how does our ball sack come into to play? Are we supposed to ignore it (move it aside), and take the height from where the pelvic bone starts? Or are we supposed to take it into some consideration?
I am 5'7.5". Standover height of 31" using the former statement as my measurement. I have been riding a 56cm up to this point (that is what I was fitted with), but I sometimes feel I should be riding smaller, because I only can put me seatpost up about 4-5" before my knees have gone beyond 30 degrees? What would be the standard size of someone with my build? 52 or 54cm? 172.5mm crank arm? 100mm stem?
bricky21
by bricky21
Is this a joke?
phourgenres
by phourgenres
No, unfortunately I am being serious.
devinci
by devinci
Hilarious!
perplex
by perplex
I could go on for a long time making amusing answers to your question, but I won't... :)
Lift aside what you can and take the measurement from the pelvic bone.
A Dane relocated to Exit 8 on the I-95 in New Jersey - and now back in Denmark
thisisatest
by thisisatest
for your height, a 56cm bike is not common. that doesnt mean it is wrong. older trek oclv bikes ran small (56cm was to the top of the seatpost clamp) and i think Fujis were (are?) similar. also, most bikes these days have some amount of top tube slope to them, so your actual "clearance" would vary. it is sometimes stated that you should have at least a centimeter of clearance, from a safety standpoint, but with no real maximum clearance guide. these are all very, very general, and for the most part antiquated, rules of thumb, to help get you in the ballpark of being sized for a bike.
note i said "sized", not "fitted". being sized gets you on the appropriate size of bicycle for that model. fitting it is to tailor the bike to fit you, kind of like a suit (you buy a suit of a given size and then have it fitted to you). that, of course involves adjusting the saddle height, fore-aft, tilt, stem length, position, and angle, bar height, position, and angle, hoods, crank length, pedals, cleats, etc...
it's hard to say if your bike is too big without more info. the amount of sack clearance is only part of it, and may be overruled by more important issues.
Greg
stella-azzurra
by stella-azzurra
For 5'7" 1/2 you most likely will find that the better size is a 52-54cm bike frame depending on your arm, torso and leg length.
Try the bike on when you are wearing your bibs, or bike shorts not your jeans, or sweat pants.
Juanmoretime
Administrator
by Juanmoretime
Yes, it is done with cycling shorts on and to use a technical term; "You need to adjust your junk out of the way and in a place of comfort"!
RESIDENT GRUMPY OLD MAN.
KWalker
by KWalker
What I like to do is ride a saddle with a cutout, such as an SMP or Toupe, and actually cut a hole in my bibs and stick my ballsack through the saddle cutout! Works every time!
Gramz
Failed Custom Bike
Roobay
by Roobay
KWalker wrote:What I like to do is ride a saddle with a cutout, such as an SMP or Toupe, and actually cut a hole in my bibs and stick my ballsack through the saddle cutout! Works every time!
Coool really coool :thumbup:
i like people... i just can't stand assholes
tonytourist
by tonytourist
:unbelievable:
I might need to try this! :smartass:
majklnajt
by majklnajt
try to stick the sack into your a$$ :D
Seriously, put them up & forward in your bibs.
naisan
by naisan
This thread has me so weak with laughter that I can barely type. . .
But it also has some practical gems that don't often get covered.
Lots of learning here. . . now please continue: I could use another laugh.
iamtak
by iamtak
you're on a 56? Let me guess, it happened to be in stock at the time of sale?
I am the same size you are and I always look in the low 50's. I know every bike and every body is different, but I cannot imagine a situation where a 56cm frame is the appropriate size for your body.
phourgenres
by phourgenres
Close, actually a deal I could not pass up on craigslist.
