Post new topic Reply to topic  [ 51 posts ]
Go to page 1, 2, 3, 4  Next
 Post subject: Watts at LT!?
PostPosted: Thu Sep 29, 2005 6:00 pm
Hi!
Following the question of what VO2 max you guys got, i would like to ask you how many watts you are pushing at lactate threshold. Please say what lactate values you measure as LT too! This varies from where you were tested.
I measure my LT at 2,2-2,5mmol, and were pushing 315-320watts.
skill
One good day makes up for ten bad ones - tenfold
 Post subject:
PostPosted: Thu Sep 29, 2005 7:37 pm
I´m at 310-315 watts at threshold. I hope to get better power next season. I´m 18 years old.
 Post subject:
PostPosted: Thu Sep 29, 2005 7:38 pm
408 at threshold. I'm 22 and a professional mountain biker.
 Post subject:
PostPosted: Fri Sep 30, 2005 3:23 am
i don't mean to be negative or anything, but a couple of points need to be brought up with regards to lactate testing:
1) what power measuring devices you are using in your lab tests? The laboratory gold standard is the Lode ergometer, which is accepted as the best, most reliable and most valid. SRM cranks also are well accepted but at a research level, the Lode is the best.
This has consequences with respect to what is a watt (pardon the pun :wink: ). My lab has a Cardgirus, a Spanish made ergometer. It is excellent but I know that 100 watts on that is easier than 100 watts on a Lode. I am definite that this varies on other ergometers as well.
2) what equipment are you using to measure lactate? once again, lab standard is equipment such as the YSI range which is quite good. equipment such as the accusport although shown in a couple of studies to be accurate can be reliable. as the above point - is 2.5 mmol really 2.5 mmol? has your equipment been calibrated with known standards prior to every test? blood lactate or plasma lactate?
don't mean to rain on anyone's parade but just some thoughts.....
cheers
 Post subject: Re: Watts at LT!?
PostPosted: Fri Sep 30, 2005 6:06 am
425 watts at threshold, VO2max is 66.
And it was on a lode.
 Post subject:
PostPosted: Fri Sep 30, 2005 8:12 am
I also tested on a Lode. I am pretty sure the lactate values are accurate. It is calibrated before each test, and as the place I was tested is a known facility where all the elite athletes in Norway is tested, I am pretty sure it is top-of-the-line equipment.
 Post subject:
PostPosted: Fri Sep 30, 2005 8:13 am
Thats great! What is your weight, and what races do you participate in??
skill
 Post subject:
PostPosted: Fri Sep 30, 2005 3:52 pm
cheers
Good points here. Personally, I don’t like the term “at threshold” because while there is a fairly standard definition for this term, many use it loosely. I prefer the more specific “Critical Power” terminology, which is simply the highest average power a rider can sustain for a given time period, typically 1, 5, 20 and 60 minutes. Maximal Aerobic Power tests are also good, but protocol dependant. In addition, absolute values alone don’t mean much; some relativistic determination must be applied, such as “watts/kg” or “watts/(kg^2/3).”
John979
 Post subject:
PostPosted: Fri Sep 30, 2005 3:57 pm
One more thing to consider about lab testing is that unless a rider is acclimated to ergometer-based riding, lab results many not accurately assess power output because your muscles are not used to riding in this fashion. Given this, it’s a good idea to ride on an indoor trainer for a couple weeks before any lab test.
John979
 Post subject:
PostPosted: Sat Oct 01, 2005 7:07 am
skill
weight is 127 pounds; I race Norba races and a few world cups. Testing is done in lab, and I train with an SRM. I also have a portable blood lactate meter that I use sometimes. I live and train at sea level, and my V02 is about 70.
 Post subject:
PostPosted: Sat Oct 01, 2005 9:36 am
xcfisher wrote:
skill
This would get you up on Alpe'duez in 37minutes, if you're able to ride on tresshold. :shock:
Go to road cycling :lol:
 Post subject:
PostPosted: Sat Oct 01, 2005 3:55 pm
Jens Voigts output is ~ 400 W at threshold and the guy weighs over 75 kg, thats 30% more than you. Ok, Jens won several Tour stages and wore the yellow jearsey twice, but who is he really anyway...? :roll:
 Post subject:
PostPosted: Sat Oct 01, 2005 4:10 pm
They told me boonen's output is around around 450-500 watts, en he's 82kg. What xcficher says is almost impossible, also because his vo2 max of 70, that's only an absolute one of ~4l.
 Post subject:
PostPosted: Sat Oct 01, 2005 5:17 pm
you have to understand those are calculations on time up alp d'huez are theoretical. I cannot ride at that pace for over 30 minutes by any means. I do not race on the road, only mountain. If you have the SRM or even Powertap software I'd be happy to send you my power profiles if you don't believe me... I was just answering to the post. No need to get defensive... :roll: I said I was a professional racer, not an amateur. The problem is your reading too much velonews and spending too much time on the internet searching for meaningless data. SHEER POWER alone is not what makes anybody a successful winner.
 Post subject:
PostPosted: Sun Oct 02, 2005 9:39 am
Nice one xc fisher! Too right.
also you guys, if there's one thing you should DEFINATELY buy this 'fall' is 'the mountain biker training bible- joe friel' You wont regret it if you're serious about your training. Unless you want to spend all winter dossing about on forums. :wink:
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3, 4  Next
Users browsing this forum: No registered users and 6 guests
There are no new unread posts for this topic. Same Watts, different bikes: different RPE?
in Training
claus
13
662
Sun Apr 21, 2013 4:47 am
claus View the latest post
There are no new unread posts for this topic. Attachment(s) Elite e-motion watts
in Training
andrey
10
1466
Sun Jan 27, 2013 6:59 pm
ultyguy View the latest post
It is currently Sat May 25, 2013 9:32 pm
