Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Thu Aug 04, 2011 1:08 pm
Hi,
Did you use cycling plans on http://home.trainingpeaks.com/ ?
Is it worth to buy a plan ( example plans Joe Friel )
Kjiu
PostPosted: Thu Aug 04, 2011 1:44 pm
I was also concidering buying one of these plans 2 months ago. I asked around, and what I ended up doing was to take a look at the programs, find similarities and workouts that seems fun and improves what I'm bad at. I then copied some of the work-outs and created my own training plan. What I got out of it?
An increase from 310w to 335w in threshold power, an increase of 710w-720w in 1-minute max and an increase in 5-minute max from 390w-410w. That's in 10 weeks time. My goal was to improve threshold power, so I did a lot of the work-outs from Hunter Allens plans. Elite 4-day and threshold improvement plan was the ones I used the most.
If you use a powermeter, create a powerprofile based on the charts you find at trainingpeaks.com, and base your training around improving your weaknesses.
If you're new to training or haven't bothered learning much about it, I would highly recommend Hunter Allens plans. However, there are no one-size-fits-all in training, and people respond different to different training. I do think however, that 100$ for a training program makes you faster than 100$ on a lighter set of cables and housing :thumbup:
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Thu Aug 04, 2011 2:15 pm
I've been using Golden Cheetah but seriously looking at TP.
Martin, where did you get some copies of training plans from?
PostPosted: Thu Aug 04, 2011 2:50 pm
I use it and only do so because I have a Mac. If you have a PC go with WKO- it has a lot of really great features that the others don't have. I hated GC for a ton of reasons and will never use it again.
As for the plans I have a friend that has many of them from attending a few of Hunter's seminars. They're nothing you can't figure out from his book if you read it correctly. If you're getting those kinds of elite numbers you must either weigh quite a bit thus lowering the p/w ratio, have responded well to structured training and/or had a great base to start with, or are some kind of budding continental pro!
PostPosted: Thu Aug 04, 2011 5:53 pm
I've seen one that a friend of mine bought (I think that was the 3-day block elite), and I've been looking at the preview of the plans.
I weigh 150 lbs, so the numbers are decent enough - the 1min is the only one thats very good. Would like to start next season with a 350 w threshold power @ 145 lbs though...
And just like KWalker said, you should get the WKO+. I like it much better than trainingpeaks online and golden cheetah. I use WKO+ on my dell windows pc, and poweragent on my macbook air. You should invest in a good software program like WKO+ and read the "training and racing with a power meter" by Hunter Allen. Lots of useful info on how to build your own training plan. I feel this would give the most value pr $.
My Bianchi Oltre XR
PostPosted: Thu Aug 04, 2011 6:08 pm
A 5 w/kg threshold and 10 w/kg 1 minute is definitely more than enough to be a competitive domestic pro in the US- good job.
PostPosted: Thu Aug 04, 2011 6:12 pm
Martin
Do you define your threshold power as ftp or as the result of a 20 min test?
Good numbers there
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Thu Aug 04, 2011 6:39 pm
I define it as the result of a 20 min test x0.95. My last 20min test had 354 w average @ a 6% avg climb. I haven't bothered going 1 hr all-out, never seems to fit my schedule lol. If only I had a nice TT bike to race on. Oh well :wink:
I've never seen such good results and progress as I have seen since I got a powermeter and a good analyzing program. It's sooo much easier to find the weak spots, work on them smart and efficiently, progress, retest and repeat. Also, reading a lot of articles and books about training with a power meter has done a lot for me as well. But the analyzing of TSS, ATL, TSB, W/kg in different intervals is golden.
Edit: Oh, and btw kjiu, you should read up on http://www.training4cyclists.com/ as well. He provides a lot of useful free info on the site. He used to be a friend of mines coach last year, giving great results. I share the same philosophy as him, you need to train at high intensities in order to improve yourself once you've reached a certain level. Combining this with FTP intervals and sweetspotintervals + LSD (long slow distance, not the drug :mrgreen: ) will give you great result. Remember to periodize and do bulks.
I guess you have some reading to do, best of luck!
My Bianchi Oltre XR
PostPosted: Fri Aug 05, 2011 2:04 am
Wish I had a 20min 6% climb to test. Im stuck with shitty roads, corners, turn arround and descending parts.
Sucks
­Twitter
PostPosted: Fri Aug 05, 2011 2:35 am
I find that its much easier to get a higher FTP test on a climb- my best was done on a 7% grade and was 10 watts higher than a test on the flats.
PostPosted: Fri Aug 05, 2011 2:58 am
Yeah of course it is. But it would make conditions much more controlable on a steady climb VS corners, descents, etc.
I used to test indoors, really not the same thing as outside.
­Twitter
PostPosted: Fri Aug 05, 2011 12:00 pm
Same here.
Although I'm now with Vince and prefer the repeatability of flat road tests. Which yield me around 25w less than what I can seem to hit on a climb...
PostPosted: Fri Aug 05, 2011 6:11 pm
I'm with you both on that notion, but I also like doing an indoor MAP test as well.
PostPosted: Sat Aug 06, 2011 12:48 am
Indoors I seem to be shocking.
I'm back to being able to hold 350-360w 20 min's in a race or proper 20min test outdoors but try and get me to do that on a trainer and I'm no chance :noidea:
PostPosted: Sat Aug 06, 2011 12:41 pm
WKO+ yes because I can set it up pretty much how I want it and I can create excel charts for what I can't.
TrainingPeaks.com no for the complete opposite reasons.
Hamish Ferguson
Cycling Coach
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 4 guests
This topic is locked, you cannot edit posts or make further replies. Ceramic bearings for BB - worth it?
NiFTY
Wed Aug 08, 2012 2:00 pm
NiFTY View the latest post
There are no new unread posts for this topic. Alfine 8 + Trek Madone... possible or even worth it?
jesiah
11
1104
Wed Jul 11, 2012 12:21 pm
seitenryu View the latest post
There are no new unread posts for this topic. Is a cannondale CAAD 4 worth restoring?
davidalone
7
883
Sat May 04, 2013 3:39 pm
lechat View the latest post
There are no new unread posts for this topic. Roval Pave Wheels worth building around?
in Everything wheels
Bostonbull
Sun Mar 24, 2013 1:23 pm
Bostonbull View the latest post
There are no new unread posts for this topic. Is it worth getting a smaller frame to save weight?
RMcC
22
1824
Tue Jul 10, 2012 10:12 pm
rustychain View the latest post
It is currently Wed Jun 19, 2013 6:33 pm
