Post new topic Reply to topic  [ 11 posts ]
 Post subject: Polar Power Kit Battery
PostPosted: Thu Aug 11, 2005 3:45 pm
Is it difficult to change the battery on the bar mounted unit?
I'm pretty sure it the battery, as the speed, cadence and power cut in and out on a ride. Bike was a the lbs for a week and the chain was touching the power kit, which is likely to have drained the battery.
"Ride it like you've just stolen it!"
 Post subject:
PostPosted: Thu Aug 11, 2005 9:06 pm
It's very easy, just use a coin to open the bar mounted unit, then the battery should come falling out.
Just make sure you securely close it afterwards :roll:
 Post subject:
PostPosted: Fri Aug 12, 2005 8:48 am
what battery does it take?
where would I get one from?
 Post subject:
PostPosted: Fri Aug 12, 2005 10:53 am
It's a simple battery, like the ones used in a watch.
There's a number on the battery so you know wich one to get.
I get my battery's from a photoshop(?), a jewellery shop should have them too so it shouldn't be too hard to find one and you could always give Polar a ring.
Good luck.
 Post subject:
PostPosted: Fri Aug 12, 2005 12:00 pm
cheers...
 Post subject:
PostPosted: Fri Aug 12, 2005 2:30 pm
The battery appear to be a standard battery use in most Camera's
Girlfriend is off to the shops to get me one...
CR123A
 Post subject:
PostPosted: Fri Aug 12, 2005 5:58 pm
:thumbup: Great!
This thread makes me want to install my power kit again, but i think it looks bad on my Storck....
 Post subject:
PostPosted: Mon Aug 15, 2005 10:37 am
Good luck.
The battery used in the power kit isn't like ones used in a watch (unless your watch is HUGE).
The battery in the bar mount (the one powering the power kit) is a CR123A and is approx 3cm long and 1cm diameter.
Really easy to replace. coin gets the cap off, replace the battery and coin gets the cap back on. And your away.
 Post subject:
PostPosted: Mon Aug 15, 2005 10:41 am
Yes, i was wrong about the battery, sorry for that :oops:
 Post subject:
PostPosted: Sat Sep 17, 2005 10:32 am
Maybe too late for you but for UK (maybe European people also) the shop price for lithium batteries like this is extortionate : I've used www.7dayshop.com in the past : pretty good service (not quick : ie around 7 days delivery !!) but very cheap and a good choice of batteries and camera related gear.
 Post subject:
PostPosted: Tue Sep 20, 2005 8:24 am
Woolworth's was the cheapest in the end £4.99. Your suggested shop sells them at £5.50. Thanks anyway...
Users browsing this forum: Bing [Bot] and 2 guests
There are no new unread posts for this topic. FTP test - Average power or normalized power?
in Training
Kermithimself
10
1362
Sat Jan 19, 2013 9:15 am
Andrew69 View the latest post
There are no new unread posts for this topic. Di2 battery charger
in Wanted
Sisbud
Mon Mar 11, 2013 9:16 am
Sisbud View the latest post
There are no new unread posts for this topic. Is it possible to put the EPS battery in a seatpost?
williamsf1
36
2908
Thu May 09, 2013 5:37 pm
g_doraz View the latest post
There are no new unread posts for this topic. Small Di2 Battery suggestion?
lemond853
Thu Jun 07, 2012 9:29 pm
lemond853 View the latest post
There are no new unread posts for this topic. Internal battery for Di2 ultegra DIY
Kingston
Wed Feb 13, 2013 5:28 pm
Cyklus View the latest post
It is currently Tue May 21, 2013 5:29 am
