It is currently Wed Jan 17, 2018 4:30 am
Post new topic  Reply to topic  [ 260 posts ]  Go to page Previous 13 4 5 6 718 Next
PostPosted: Mon Dec 14, 2009 5:18 pm
grover wrote:
Slight sidetrack; has anyone figured out how to download ride data from the Edge 500 into trainingpeaks yet? Google points me to lots of press releases about it being compatible but no instructions on how to make it compatible.
HERE
 Post subject: Re: Garmin Edge 500
PostPosted: Tue Dec 15, 2009 9:10 am
^^^^^^^link not working for me.
anyway, I got Device Manager 3.0 from the trainingpeaks website. It downloads data from the Edge 500. Now I just need to figure out how to get data from Device Manager to WKO+.
PostPosted: Tue Dec 15, 2009 10:56 am
stevei wrote:
When riding over a bumpy road surface, the clip that is supposed to hold the 705 in place can bounce enough to release the 705.
I think you are doing something wrong. I swap my 705 between my road and MTB. It has taken some fairly rugged descents on the mtb, plus a few occasions
when I've smacked bits of my body against it (ouch) while failing to make it up climbs. Never has
that clip released. In fact it takes a reasonably solid push to release it and given the mass of the lever, the chance of that happening through inertia seems
like zero to me, unless you ride off the top of a building.
Graham
PostPosted: Tue Dec 15, 2009 3:47 pm
The link works for me. In any case, DA 3.0 saves your data here: My Documents\TrainingPeaks\Device Agent\saved\<whatever name username
you have, default is unkown>
You can associate the *.pwx file with WKO+ so all you need to do is make a desktop shortcut to that folder and then click on the new download (which will launch a session of WKO+ with that workout as the activity).
PostPosted: Wed Dec 16, 2009 4:31 am
Shop Wrench
I was thinking the same thing. I guess some people are harder on stuff than others. I have over 1000miles on my mtb this year with the garmin and it has never come off, loose, crooked. I have never broken a mount or anything. I actually just a month ago broke the release tab on my road bike when I got home from a very cold and rainy ride. The mounts on my other 2 bikes are still working perfectly.
PostPosted: Wed Dec 16, 2009 5:43 pm
Mine requires almost zero force to move the lever to release the 705, I would estimate just a few grams of force, the lever bends extremely easily. I wonder if there are different versions of the mount around. Mine is a one piece design that came in the box with the device. I'm not sure what exactly I could be doing wrong with it, I mean it just slides on and the retaining mechanism clips into place. I honestly don't know how exactly it has come off, just that twice it has come off when I've pushed the lap button at the top of a hill climb. My guess is that it had already come loose at that point, and pushing the lap button just gave it the final push to come off the mount. After the second time I applied tape to the underside to make it a really tight fit on the mount, so that it now requires several kg of force to remove it, and it hasn't come off since.
I might add that it has only ever come off my road bike, not my MTB, though I haven't used it a huge amount on an MTB. I think in many ways it gets a worse type of vibration on the road bike than the MTB. The road surface on one of the hills where it happened is truly dreadful, and someone else once told me that their 705 had on several occasions switched itself off at the top of the hill, which I suspect is also related to the pounding it gets from the road surface there.
PostPosted: Mon Dec 28, 2009 2:54 pm
Well most of you seem to like it. I have one on order for my cross bike. Can't wait to play with it.
PostPosted: Fri Jan 08, 2010 9:41 pm
After a weeks worth of power tap training with the 500 it looks like the readings are more optimistic than my LYC that came with the cyclops.
Anyone else having this problem and if so are there any fixes? I have already updated the formware on the garmin to the latest version.
Zippmania
PostPosted: Sat Jan 09, 2010 3:26 am
Have you zero'd it w/the 500? What makes you think the readings are optimistic?
PostPosted: Sat Jan 09, 2010 12:11 pm
I have zeroed the unit by warming the hub up to operational temperature and then stopping. I then do a re-calibration and it says successful after that.
The readings are a little higher than the LYC but the temperature in my garage was minus 8 degrees C when I was training so maybe that would have something to do with it?
Z
PostPosted: Sat Jan 09, 2010 3:44 pm
Are you using WKO+? If so, post screen shots of the workout summaries.
PostPosted: Sat Jan 09, 2010 11:40 pm
Using Garmin connect on line but I am thinking of going on to WKO+, is this advisable as the information on the Connect sw is not as concise as the Power agent information.
Z
PostPosted: Sat Jan 09, 2010 11:51 pm
WKO+ is worth it if you are serious. You can do a 14 day trial as well.
PostPosted: Sun Jan 10, 2010 12:13 am
half way down page
http://pedallingdave.blogspot.com/
PostPosted: Sun Jan 10, 2010 6:56 pm
I am going the WKO+ route as my race season starts in March !!!!
Thanks for the pointers Dave.
Z
There are no new unread posts for this topic. Garmin Edge 520
in Wanted
vladoo
Tue Dec 26, 2017 12:23 pm
vladoo View the latest post
in Wanted
vladoo
Tue Dec 26, 2017 12:39 pm
There are no new unread posts for this topic. Garmin Edge 1030
WheresWaldo
12
1759
Tue Jan 02, 2018 10:29 pm
MichaelB View the latest post
There are no new unread posts for this topic. Garmin releasing a new Edge computer soon?
[ Go to page: 1 2 3 4 ]
SpecializedColnago
47
5765
Wed Nov 01, 2017 10:47 pm
There are no new unread posts for this topic. Garmin Edge 1030 and Vector 3
[ Go to page: 1 2 3 4 5 6 ]
Tillquist
84
15715
Tue Jan 02, 2018 11:36 am
mrlobber View the latest post
Users browsing this forum: No registered users and 2 guests
cron
