Post new topic Reply to topic  [ 260 posts ]
Go to page Previous  1 ... 13, 14, 15, 16, 17, 18  Next
PostPosted: Fri Dec 31, 2010 2:09 pm
I went with the US National grid. It was correct.
I gotta say, this is the nicest bike computer I've ever used. Easy, accurate and looks great. I'm happy now that my Polar computer broke ;)
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Mon Jan 10, 2011 10:05 pm
Hi,
Mine takes at least a couple of minutes from turning on to connecting to satellites. Is this normal?
Just wondered,
thanks
PostPosted: Mon Jan 10, 2011 11:12 pm
Yes, normal. It's trying to use timing differences from signals from satellites orbiting the earth to pin down your position. So there's a lot of simultaneous equation solving going on to get a fix, then after that it can update very quickly, no doubt using some shortcuts. Thus if you switch it off, then on again within an hour or something, it restarts very quickly. It's also quicker to re-fix if you keep still so that it's not trying to work out where it is while moving as that increases the error of the fix.
Personally I'm very pleased with my Edge 500. I figured out how to upload courses to it from bikeroutetoaster.com recently and found that I could use it to do 35 mile routes on back lanes I'd never used before without getting lost or riding more than 400 metres on a main road! For that it's worth the purchase price alone as I could never be bothered to do that with a map as I would be checking turns every 5 minutes and questioning my sanity after 3 right turns in a row.
It even has turn indicators, i.e. in 200m turn right... It's not as good as car sat nav, but perfect for training in a new location or doing a sportif ride. Also even if you have no course pre-loaded you can look at the course map and see where you've been so that you can get back to the start. Also you can repeat exactly the same route and compare times etc... So now I know our tandem is much slower overall on rides, but only because I ride much harder on my own. It's aboiut as fast on the flat for much less effort. No surprise, but nice to know.
If you need more than this, probably better to look for a new hobby like orienteering, MTBing or rambling.
PostPosted: Fri Jan 21, 2011 6:15 pm
Enjoying my new Edge 500. Some weird behavior with Garmin connect though.
I have only a power meter installed (Powertap). No speed or cadence.
Garmin connect is reporting a cadence graph on every ride though :noidea:
Any idea?
PostPosted: Fri Jan 21, 2011 7:25 pm
Your PT provides a cadence estimate to the Garmin. I guess it judges by the dead spot in your pedal stroke. The average is actually really accurate.
PostPosted: Fri Jan 21, 2011 8:51 pm
It has to report cadence as that's how power is calculated. I also found it very accurate.
R3 S3 P3C BT X1 | put it in the big ring
PostPosted: Fri Jan 21, 2011 9:25 pm
Cool. Thanks for the feedback. I did not realize that. Turns out that I thought this was pretty accurate but had no idea how it was done!
PostPosted: Sat Jan 22, 2011 3:34 am
Cadence has nothing to do with the power calculation. Wheel rotation does.
Cadence is calculated by the power peaks in your pedal stroke. Peak power is ~2x avg power per stroke so it's pretty easy to pick out although it's limited to 40-120 rpm with the Powertap (or was with the LYC/Cervo)
PostPosted: Sat Jan 22, 2011 4:14 am
Ah yes - Powertap - my bad. Too used to SRM / Quarq.
PostPosted: Sat Jan 22, 2011 2:57 pm
Another Garmin connect question. ONce you have downloaded an activity there is there any way to extract the original .fit file ?
PostPosted: Sat Jan 22, 2011 5:27 pm
Nope, only a .tcx file, AFAIK
PostPosted: Tue Feb 01, 2011 2:53 am
Garmin confirmed to me that GTC cannot create workout with power zones. They recommended to create the workout directly on the device which is a real pain.
Is there any non garmin SW that can be used to create workout with power zone and download them into the Edge 500?
PostPosted: Tue Feb 01, 2011 5:55 am
Interesting, I can
PostPosted: Tue Feb 01, 2011 9:09 am
I think you can just grab it straight of the CPU via Windows Explorer or similar.
PostPosted: Tue Feb 01, 2011 2:28 pm
rgkicksbutt wrote:
Interesting, I can
what sw is that GTC?
Post new topic Reply to topic  [ 260 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18  Next
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. New Garmin Edge 810 and 510
[ Go to page: 1 ... 10, 11, 12 ]
in GPS, Strava, Ride pics and adventures.
markyboy
179
15131
Sat Apr 13, 2013 11:56 pm
djm View the latest post
There are no new unread posts for this topic. Garmin Edge 500 w/ HR Strap
DividedVolta
Thu Mar 14, 2013 6:34 pm
DividedVolta View the latest post
There are no new unread posts for this topic. Garmin Edge 705 $135 + Shipping
willwork4rice
Mon Feb 18, 2013 8:14 pm
willwork4rice View the latest post
There are no new unread posts for this topic. Garmin Edge 500 - 2013
tomaz69
Sat Jan 05, 2013 12:38 am
dvincere View the latest post
There are no new unread posts for this topic. Garmin Edge 800 bundle (SOLD)
Bianchi10
Sat Mar 30, 2013 12:59 am
Bianchi10 View the latest post
It is currently Sun May 26, 2013 3:16 am
Garmin Edge 500
