It is currently Sat Apr 29, 2017 7:03 pm
Post new topic  Reply to topic  [ 274 posts ]  Go to page Previous 115 16 17 18 19 Next
PostPosted: Sat May 08, 2010 12:01 am
Both my dad and I use our powertaps in the rain regularly and have never had a single issue. They do their job, there is just the drawback with the wheels.
Gramz
Failed Custom Bike
PostPosted: Sat May 08, 2010 4:41 am
devinci wrote:
I'd really go toward wireless SRM cause i'd like to train with it on my road bike AND my TT bike... I dont think the wired one would allow this?
As Tapeworm has already suggested. Just buy a second wiring set and make sure both bikes are running the same BB. Couple minute job to swap between bikes.
I've gone second hand wired SRM twice and have had no issues - if you hunt around you can pick up some bargains. I recently bought a wired FSA SRM for my TT bike for AU$630! Had it checked after buying and getting it recalibrated with the new chainrings - even the batteries were still fine!
If you are still set on wireless, I'd go with the Quarq matched to a Garmin. They have been around long enough now to show reliability and accuracy.
PostPosted: Sat May 08, 2010 11:16 pm
I thougth about qarq with garmin edge 500.
Can anyone tell me if the qarq system AND the garmin edge 500 are available right now or if I gotta wait for it?
thanks
PostPosted: Sun May 09, 2010 12:02 am
Yes, both are, but some crank options have a wait time and it will be pricier if you don't supply your own crank arms.
Gramz
Failed Custom Bike
PostPosted: Thu May 20, 2010 12:18 am
Winter training. Well here in Chandler, AZ, its gets soooooo cold. In fact The 35-40 degree early mornings are so cold that I ride over lunch when its at least 65 degrees or in the evening after work when its 55. I usually have to at least use knee warmers and most times full leg warmers w/ long finger gloves. Life is so tough here. Well, not really, I'm just a total wuss. I can definately tolerate the heat though. I can race in 105-110 weather and do well.
Chiva
PostPosted: Thu May 20, 2010 3:57 am
You are a wuss. I used to live/ride/train in Tempe and I used warmers a half dozen times. Up here in Central NY I was using both off and on until last week and I didn't have a warmer free ride until April
Gramz
Failed Custom Bike
PostPosted: Thu May 20, 2010 8:08 am
http://www.philipdeignan.com/node/73 wrote:
I have different training zones and the endurance rides are my zone two which is 250 watts on rolling terrain with two or three low cadence, high power sessions thrown in on some good drags or steep climbs.
From this week on I will be focusing more on my intensity training which all about riding for 1.5 hours or two hours at 300 watts. I will also start work on improving my climbing which involves riding a nice 20 minute climb just on my threshold.
I like this guy. :up:
Hell yeah!
PostPosted: Thu May 20, 2010 12:55 pm
BTW, im might buy an SRM amateur, if you guys could give me insights on the reliability of the system, even though it is +/-5% accurate. I think if I always train with it, it can be fine, although not that accurate, somehow it might be fine for training? Do you really need to be that much accurate with power while training since you often train between ranges of power (zones)
thanks
PostPosted: Thu May 20, 2010 9:55 pm
You AZ guys make me ill! :wink: I would give my eye teeth for 35-40 degrees. We get -35 to -40 degrees! If it is warmer than 10 degrees and not snowing, we ride out here (otherwise the cassettes ice-up).
PostPosted: Sun May 23, 2010 10:42 pm
I am a wuss. I'm so used to the heat extreme that a little cool weather kills me. I do go up to southern UT in the late fall and ride a bit. About 25 degrees F when I leave the house and about 15 degrees at the summit (9,600 ft). That descent is a cold, brutal beast. Even if I ride up w/ jersey full unzipped, the sweat still gets the kit a bit damp which feels like ice water on the way down. I admire you cold weather guys. You dudes are true hard-men! I wear full leg warmers and long-fingered gloves more often than I would like to admit.
Chiva
PostPosted: Mon May 24, 2010 7:31 am
You should try doing the Stelvio. 25 degrees when we started, 3 degrees and rain at the summit. That's turnes out to be one long and cold descent.
Hell yeah!
 Post subject: Planning winter training
PostPosted: Thu Sep 26, 2013 10:53 pm
Wtf I don't even know how this got here. I didn't even have this tab open :noidea:
PostPosted: Thu Sep 26, 2013 11:17 pm
Well what do you want to win next year and when are those races? What will it take to be in for the kill when it matters? All these numbers are great but they are just a means to an end. For me, our 2014 race calendar won't be released till Jan~Feb next year so I focus on making my wife like me again right now so I can actually do the races I want next year.
Sent from my Galaxy Nexus using Tapatalk 4
PostPosted: Fri Sep 27, 2013 12:43 am
I see torque as fairly irrelevant here. What I understand is you want to increase your FTP. From a pure endurance cyling performance I see very little value and evidence yet in weight training. Same applies for low cadence intervals or whatever you want to do with cadence, torque and efforts.
Why not focus on higher intensity efforts above FTP? It has been shown efforts around 90% Vo2max are a strong stimulus for skeletal muscle adaptations, just as L3-L4 is supposed to be. With higher intensity efforts, you need a lower total work volume and you may even drain a bit less muscle glycogen, which would make recovery faster. Well trained athlete may not get the most out of continuous work as much as they would get out of high intensity intervals.
I think its worth a try, it would make your training more diversified if nothing else.
PostPosted: Fri Sep 27, 2013 11:50 am
Martin post is missing
There are no new unread posts for this topic. Attachment(s) Share Your Scotts...
ryanw
23
3826
Thu Apr 13, 2017 9:13 pm
toshi View the latest post
There are no new unread posts for this topic. Share your Road tubeless setups
[ Go to page: 1 2 3 4 5 6 ]
in Everything wheels
prebsy
88
7559
Fri Apr 28, 2017 1:17 pm
CrossRob View the latest post
There are no new unread posts for this topic. Lets see your S5 Garmin mount solutions
[ Go to page: 1 2 3 4 5 ]
Shrike
66
3827
Mon Apr 03, 2017 2:37 pm
hongsj View the latest post
There are no new unread posts for this topic. Not as fast on new bike - any ideas?
in MTB
DigitalArt
16
1464
Mon Nov 21, 2016 6:59 pm
boots2000 View the latest post
There are no new unread posts for this topic. Climbing bike project ideas....!!!
Neckkoss
83
6470
Tue Apr 11, 2017 5:15 pm
milesthedog View the latest post
Users browsing this forum: No registered users and 1 guest
