It is currently Wed Jan 17, 2018 12:27 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Fri Jun 05, 2009 2:04 am
Rich_W wrote:
Any insights or discussion would be appreciated.
Go outside!
I think I'd rather have a colonoscopy than ride 20 minute intervals on the trainier.
FWIW, I've put my powertap on the computrainer before and they're both within a watt or two of each other.
- Zipp rims will break if you look at them too hard
- R-Sys wheels will spontaneously explode
- The ZG crankset will never, ever exist
- Everyone needs Lightweights, even if they're fat and old
- Parts actually made of metal are SO 10 years ago
 Post subject:
PostPosted: Fri Jun 05, 2009 6:39 am
This past winter I did a lot of work on the trainer and rollers. It is tough to get the 2x20's in when you are indoors. It just feels like crap when you are working that hard and not going anywhere. Fans are ok, but your body knows that it is not moving and it feels odd. I struggle to find a spot where I can keep the power constant, whether it is a hill or the flats. That said, the rollers or trainer are the only place where you can really dial this in and keep it toally constant. It does hurt more than outside though.
As a newbie to training with power, I noticed this issue the first time I got on the rollers with the power meter. It kind of sucks!
 Post subject:
 Post subject:
PostPosted: Fri Jun 05, 2009 7:58 am
I partially disagree with saeco.
2x20' on the rollers are hard, that's sure, however once you get a little used it's great quality IMO (plus some good music helps a lot). It's hard to keep such a steady pace on the road because of terrain/etc...
Only caveat, when I was doing a lot of 2x20 on the rollers with the powermeter I had to almost ignore my "road" power zones and aim for lower wattages.
 Post subject:
PostPosted: Fri Jun 05, 2009 10:42 am
It's possible to stay in the target zones but it can be brutally hard mentally. There are people who have less problems with it but most racers I know hate the trainer. I can adapt to the rigors of indoor training to a certain degree (the psychological strain of not riding at all vs. suffering on the trainer).
I rarely do more than one hour on the trainer, getting a good TSS of 70-80 out of it which is more than enough during winter. I'd rather add another hour of running which at least gives me a taste of freedom in nature, a workout for the upper body, some aerobic fitness and another (virtual) TSS of 60.
 Post subject:
PostPosted: Mon Jun 08, 2009 11:43 pm
i have the same dilemna with my powertap, doing 300 watts indoors feels like 400 outdoors.
and im going hard but power is way lower.
 Post subject:
PostPosted: Tue Jun 09, 2009 5:30 am
Watts are watts. They feel harder indoors because riding the trainer sucks. :wink:
Have you ever wondered if there was more to life, other than being really, really, ridiculously good looking?
 Post subject:
PostPosted: Wed Jun 10, 2009 1:42 am
I found this a interesting read onthe subject.
http://alex-cycle.blogspot.com/2009/01/ ... ining.html
 Post subject:
PostPosted: Thu Jun 11, 2009 12:54 pm
Yes wattage on a trainer dose feel diffrent than wattage on the road dunno exaclty why but I would say alot has to do with diffrence in cadence changes and actual just feel of the bike while doing either. When riding my trainer (1upusa) my lactic threshold is around 275 and while on the road this spring I was able to maintain 315-325 with the same PE. I would just have to say its the nature of a trainer get use to it, although in the future when they start making trainers that cost 2 or 3k and simulate the rode from a computer model perfectly (yes i know about computrainer) then thats when things change.
put the fun between your legs
PostPosted: Wed Oct 28, 2009 2:23 am
Rich,
Just pin on a number and go race!
Drop the PM and put it on the line.
BTW
Guess who?!? :twisted:
PostPosted: Mon Nov 09, 2009 10:10 pm
It takes some time to get used to doing the long effort intervals on a trainer. Don't stress so much on hitting a home run everytime, just go by "alls you can do is alls you can do." Eventually (it took me about 2 months) your indoor and outdoor wattage will become more similar. Good luck!
PostPosted: Sat Aug 10, 2013 10:49 pm
Hi all.
Has anyone else had experienced this. My training bike is set up with a powertap hub. I use it to commute to work and out training. I have a nice 20 minute climb which I can ride up at 260 watts while my Heart rate was roughly about 155 - 160. I can also power up a 4 minute climb at around 350 watts.
Yet when I go on the turbo and try and do 300 watts for 3 minutes my heart rate shoots up way above 175 and I really struggle.
I can't understand why if its harder on the turbo then why aren't my watts showing a higher number?
Any ideas ?
Paul
merged, as there are many threads on this
PostPosted: Sat Aug 10, 2013 11:47 pm
I find very low correlation between anything on a turbo trainer or rollers and the road. I think it is a combination of "mechanical impedance" factors and psychological factors. Trainer/rollers are always much lower power numbers for me too.
PostPosted: Mon Aug 12, 2013 9:52 am
Heat and the difference in inertia I believe are the biggest contributing factors to the differences you see between indoors and outdoors. The type of trainer you use changes this but as a XC racer I believe working on lumpy low inertia trainers helps prepare my pedal stroke for very steep climbs. Provided that trainer can produce enough load that is.
There are no new unread posts for this topic. Indoor trainer: gradient vs wattage (still don't get it)
in Training
Sir Rides a Lot
Thu Sep 28, 2017 2:45 pm
Sir Rides a Lot View the latest post
There are no new unread posts for this topic. Textured Tires on trainer
misterq
Sat Sep 16, 2017 10:38 am
Kaboom View the latest post
There are no new unread posts for this topic. Smart Trainer Apps?
eyedrop
Thu Nov 02, 2017 10:14 pm
glepore View the latest post
There are no new unread posts for this topic. Sinuisitis and Indoor Trainer?
in Training
3Pio
10
867
Tue Oct 31, 2017 2:11 pm
topflightpro View the latest post
There are no new unread posts for this topic. Trainer control in erg mode
in Training
kytyree
Fri Apr 14, 2017 1:20 am
slick1 View the latest post
Users browsing this forum: No registered users and 1 guest
cron
