Post new topic Reply to topic  [ 8 posts ]
 Post subject: Polar HRM Caloric Data
PostPosted: Tue Mar 15, 2005 3:38 pm
How accurate do you think the data from Polar HRM is concerning calories burned? I've read in other postings that the power output (watts) can be off by as much as 5 to 10%. If there is an inaccuracy in power data then surely the caloric data would be off too. If it is off, how does it vary, positively or negatively (from the actual amount of calories burned)? Or is all this just unsubstantiated rumours?
Its a joke! (the Avatar)
 Post subject:
PostPosted: Tue Mar 15, 2005 4:24 pm
It depends on the model you have. The S serie models are very accurate as the models below that aren't.
 Post subject:
PostPosted: Tue Mar 15, 2005 4:52 pm
First, Polar power meters are more accurate than you hear or read. Second, both are calculated independently. Polar uses an algorithm based upon various factors including age, weight, sex, heart rate, duration to estimate calories burned. Its accuracy is variable for many reasons, but it does provide a rough estimate of calories burned, but probably not accurate enough if you were strictly counting calories to lose weight.
One of the advantages of a power meter is that they measure kilojoules of energy expended, and kilojoules are easily converted to kilocalories. The only problem here is that human efficency varies from something like 21% to 26%, so even knowing your kilojoules of work there is going to be some inaccuracy regarding calories burned.
BTW, I just compared two power meter files, one a Polar, the other a Powertap. Same ride, exactly one year apart. Almost identical conditions, distance and average speed. The average power measured by the Polar and Powertap was the same, with only a 34 kj difference in work.
Looking even closer, I looked at the data from a small climb:
Polar
Duration: 5:20
Work: 109 kj
Distance: 1.387 mi
Min Max Avg
Power: 176 474 342 watts
HR: 145 177 171 bpm
Cadence: 73 98 85 rpm
Speed: 12.6 19.8 15.6 mph
Powertap
Duration: 5:38
Work: 110 kJ
Distance: 1.392 mi
Min Max Avg
Power: 122 431 325 watts
HR: 120 228 163 bpm
Cadence: 59 103 88 rpm
Speed: 9.1 21.3 14.9 mph
The higher power reported by the Polar is indicated b the faster speed on the climb. Soon I wll be doing simulanious comparisons.
John979
 Post subject:
PostPosted: Tue Mar 15, 2005 6:03 pm
I am using the A5 unit, is this one know for accuracy?
a5-mid.jpe
 Post subject:
PostPosted: Thu Mar 17, 2005 8:40 am
I did read a scientific article based on proper lab tests and they reckoned the Polar calorific/power/VO2max calculations were within 8% for the vast majority of the population provided you had calibrated the HRM properly to your own parameters.
 Post subject:
PostPosted: Fri Mar 25, 2005 5:11 am
I used to use the 720 to approximate my caloric output. I found that it under estimating my output, as I based my caloric intake ( + basal rate) on it. I was dropping weight too quickly. I multiplied the Polar value by 1.1 or 1.2 to offset the error. I would urge you to be careful with this number... remember, it's just a number, and it doesn't really reflect what your body is doing or what it needs.
To be honest, I stoppoed paying attention to my diet some time ago. I found that a healthy-well-ballanced diet with lots of fruits and vegies (and not a lot of meat) keeps the weight off. Add in a multi vitamin with iron, and 15-20 hrs a week on the bike, and I gaurentee you'll be at optimal weight right quick. And you don't have to count calories or go deep into calorie debt (and feel like crap all the time). Trust me, when you eat well, you feel good. When you feel good, you ride faster!
:-) Toys-R-Us
PostPosted: Sat Mar 26, 2005 11:57 pm
that is like 1200 an hour? jesus
I rode 6 hours for 110 miles today and estimated 3000 burned. am i wrong?
 Post subject:
PostPosted: Sun Mar 27, 2005 2:21 am
I did an 80 mile ride today of just over 4 hours that required 2945kj of work. This is net work. To get calories, use one of the following conversion factors:
25% efficient, kJ × 0.96 = kcal,
24% efficient, kJ × 1.00 = kcal,
23% efficient, kJ × 1.04 = kcal,
22% efficient, kJ × 1.09 = kcal,
21% efficient, kJ × 1.14 = kcal,
I would assume 23%, thus I burned 3063 calories on this ride, excluding BMR.
One of these days I will hook up the Polar and see what it calulates.
John979
Users browsing this forum: No registered users and 4 guests
There are no new unread posts for this topic. Kinlin Aero Data
in Everything wheels
rijndael
Thu May 30, 2013 4:33 pm
WMW View the latest post
There are no new unread posts for this topic. New tire rolling resistance data.
[ Go to page: 1, 2, 3, 4 ]
Juanmoretime
47
2654
Sun Feb 10, 2013 12:28 am
fdegrove View the latest post
There are no new unread posts for this topic. Kinlin XR-300 mass: interesting data point
youngs_modulus
7
1059
Sat Nov 17, 2012 8:10 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. Attachment(s) New frame testing data comparing top bikes (by Giant)
Ryan94
57
5569
Tue Oct 16, 2012 3:53 am
53x12 View the latest post
There are no new unread posts for this topic. Golden Cheetah: Garmin data import Questions
in Training
Rick
13
766
Sat Apr 06, 2013 6:16 pm
Rick View the latest post
It is currently Wed Jun 19, 2013 11:25 am
