Post new topic Reply to topic  [ 217 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 15  Next
 Post subject:
PostPosted: Thu Jan 22, 2009 8:39 pm
beatnik I can host it as a single downoad for you if you don't have webspace.
 Post subject:
PostPosted: Thu Jan 22, 2009 8:46 pm
Yeah, I'm having issues downloading it, it'd be easier just converted and represented in one peice if you can Beatnick. :)
Guildford/Woking is the home of F1.
We make loads of other stuff here too.
 Post subject:
PostPosted: Fri Jan 23, 2009 10:38 am
Forum has limits, you can´t upload rar files or a file bigger than 156 k. Winrar can be downloaded here
http://www.rarlab.com/rar/wrar380.exe
Biomechanical spreadsheet. Sizing&Fitting.
http://weightweenies.starbike.com/forum ... 8e319d185b
 Post subject:
PostPosted: Fri Jan 23, 2009 11:30 am
Thx :lol:
 Post subject:
PostPosted: Fri Jan 23, 2009 12:02 pm
try this
http://antonyl.brinkster.net/beatnik/Bi ... nglish.xls
 Post subject:
PostPosted: Fri Jan 23, 2009 12:04 pm
Thx Ant, you are very kind. I put your link in the first message.
 Post subject:
PostPosted: Fri Jan 23, 2009 12:21 pm
Just repaying you for the effort you put in for me.
 Post subject:
PostPosted: Fri Jan 23, 2009 12:22 pm
The karma rules ;) :lol: Thx again :oops:
 Post subject: fantastic
PostPosted: Tue Jan 27, 2009 4:56 pm
guys
I raced in the 90's and my position was set up using bioracer. This spreadsheet is a great starting point, although slightly different to my measure ments from 1995
However, I agree with the 10 cm stem rule which I recall helps with weight distribution?
Im doing a comeback and its interesting as Ive lost my flexability:
http://www.mid-life-crisis-etape-2009.blogspot.com/
 Post subject:
PostPosted: Fri Mar 13, 2009 4:56 pm
amazing speadsheet! I obtain 95% coincidence with my fit, hardly developed for a 30 years :) Great respect..
 Post subject:
PostPosted: Mon Mar 16, 2009 7:29 pm
Thx :oops: :oops: :oops:
 Post subject:
PostPosted: Tue Mar 17, 2009 5:33 am
I've seen this excel file for about three months now, and finally decided to play around with it on my two already established fit road bikes (may not be the most efficient, "perfect comfort")
They are super close! Wow! Another thumbs up! I played around a tiny bit and hopefully this will increase my wattage!
 Post subject:
PostPosted: Thu Mar 19, 2009 5:49 am
I'm a little worried now...
I've just been fitted by my store to a 58cm bike. And they used a bit fit system...
I'm 6'1" and my measurements are pretty much the same as in that spreadsheet and it says I should be 56.5....
mmm?
 Post subject:
PostPosted: Thu Mar 19, 2009 10:32 am
58 Horizontal or 58 vertical?. I guess it´s vertical, and if you have my measures that´s the best for you.
The ss. recommends the best frame (custom) according to your body, but with std. geometry we have to play with the stem. I have considered a 10-11 cm stem for an horiz. perfect fit, according to that the best frameset horiz. is the one i recommend. Std. stems have that measure and that´s the way to do it, without a stem length it´s impossible to fit a bike horizontally.
You have short arms and torso for your inseam and you will need short stem. In this case we have another problem, saddle-handlebar drop and lower back pain, you will need more spacers or positive angle stem to fit your drop perfectly.
Reg.
 Post subject:
PostPosted: Sat Apr 25, 2009 5:08 pm
Hi Beatnik,
thanks for the sheet, very interesting. I have been trying to figure out what my fit should be - interesting to learn about it.
Couple of questions:
- In the sheet I downloaded the flexibility measurement doesn't seem to change anything. The field says 'number stored as text'. - is that intentional?
- I would also be interested in knowing how I would fit on triathlon bike with a 78 deg seat angle. Do you also have a fitting sheet for that?
Btw, I have a 99cm inseam and 53cm lower arm. It's quite difficult to find the right kind of frame for that...
Post new topic Reply to topic  [ 217 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 15  Next
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. Attachment(s) Bike Fitting (Serotta Get Fit Spreadsheet)
epjohnson
Sat Sep 15, 2012 5:30 pm
epjohnson View the latest post
There are no new unread posts for this topic. Lezyne Micro Floor Drive - HP Version
Valbrona
Sat Jul 14, 2012 3:30 pm
sungod View the latest post
There are no new unread posts for this topic. Power Profile Chart updated version
in Training
debock.robby
Mon Aug 06, 2012 11:38 am
ajmitchell View the latest post
There are no new unread posts for this topic. SRAM R2C TT shifters. Brand new! (improved version) $200.00
eigner
Sat Mar 02, 2013 5:33 pm
eigner View the latest post
There are no new unread posts for this topic. 2010 Campagnolo Athena Cranks (Carbon, UT version)
verycreativeusername
Tue Apr 02, 2013 10:44 am
verycreativeusername View the latest post
It is currently Sun May 26, 2013 3:22 am
