It is currently Wed Jun 28, 2017 4:36 am
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: Trainers vs. rollers
PostPosted: Sat Jun 26, 2004 8:30 am
I'm in the market for one or the other. I know the obvious: rollers work on form, trainers on power. But are there other benifits? Which do you guys ride, and what do you like about them?
 Post subject:
PostPosted: Sat Jun 26, 2004 9:38 am
I personally use some CycleOps Fluid Trainer - It's quite good, but hasn't got the best of adjustment.
Rollers are better, they also allow for you to get some kind of reading on your computer of your speed.
I have heard of people have accidents on roller's. A bike shop worker told a beginner cyclist to learn with rollers...She somehow disengaged from the rollers and flew forward, into the wall of her lounge!! :lol:
 Post subject:
PostPosted: Sat Jun 26, 2004 9:59 am
I've known of an experienced rider who broke his arm after riding off the side of his rollers :oops:
Uphill MTB is good for form, if you pedal in squares your back wheel will slip.
I train for power so I've got a mag trainer.
 Post subject:
PostPosted: Sat Jun 26, 2004 10:08 am
I have TACX rollers, I use them mainly in the winter, when it snows (cold doesn't bother me) and for revalidation purposes (as I am now revalidating from pheumonia).
Also when you want to do a thorough warmup before going out for an interval training they are OK. Also for a cooldown I use them. Coming in from heavy training with MTB and then hopping on the rollers for a 15 minute cooldown.
I have a mechanical brake on them but I rarely use it.
As you can see, the front of the bike is fastened, it beats falling off !
Auribus teneo lupum
 Post subject:
PostPosted: Sat Jun 26, 2004 2:30 pm
I generally try to ride outside most of the year on my MTB however there are months here that it is just not feasible. We have two distinct seasons Winter (late October to early April) and Summer. In the early Winter I ride on rollers and then switch over to a Mag trainer in January to start building power. I like the rollers after a season of racing for recovery and to work on form. I have on occassion crashed but normally only after you become complacement while on the rollers. Many when first using rollers put them in a door frame so if you start to come off you can reach a hand out to steady yourself. With practice you can get to the point where you can ride no hands (which you can only do with a very balanced peddle stroke). You can get an excellent work out on both. When I switch over to the mag trainer I work on heavy resistence training only. Regardless of what I train on I don't watch TV. I often listen to Music that is fast so my training will follow the beat of the music. By spring I'm ready to see the end of both. I know what a pet rat in a cage with one of those running wheels must feel like.
 Post subject: Rollers...again
PostPosted: Thu Jan 06, 2005 10:34 pm
Roolers or Trainer? I think it depends on training goals. If you seek enhanced form and concentration, rollers are best. If you value power, simplicity, ease of use and lengthier training sessions, use a trainer. I was intrigued by rollers, but weighed the pros and cons of cost, safety and training goals and bought a high-quality fluid trainer. While I remain intrigued with using rollers some day, my training goals mean more to me than intrigue. Cheers.
PostPosted: Fri Jan 07, 2005 11:46 am
If anybody is interested in a totally unique and newly designed, extrememly beautiful set of rollers then please contact me.
Can't say any more as they are not released to the public yet, but there is nothing like this product on the market in the world!
It is a work of art though I can tell you, and only for riders that want the best, most beautiful product to train on.
Thanks
 Post subject:
PostPosted: Mon Jan 10, 2005 4:56 am
Personally I use a mag trainer, it is great for throwing the bike on and warming up or doing intervals and other exercises. I use the trainer if I don't have time to ride in the day
they are compact and easy to store, and are a good stand for the bike
I find that the mag trainers are much harder to use than real riding cause the resistance is linear.
I can never do more than an hour and a half and after a while the trainer can drive you batty, I can't do it without music.
all and all if you have a MTB, Nothing beats the opportunity to go out and ride. I've been riding outdoors on my beater (MTB) pretty well every day this year even though the ground is covered with snow and ice. I find that riding on the snow and ice really help develop form, and motivates the rider to use proper gearing as one cannot easily maintain traction on ice when climbing out of the saddle (I don't use studs). Most people think that I'm batty, (Which may be true) but riding out in the muck is great for form and is a lot more exilirating and fun specially if you have a good fall or two (I've had a few in the last couple of weeks)
Jack of all trades, master of none.
 Post subject:
PostPosted: Mon Jan 10, 2005 3:57 pm
I am looking for a trainer too but I've heard some bad stories. Is it true that a trainer just eats away you're rear tire ? How many hours of training one can get out of a normal tire ? Elite uses elastogel to minimise this problem, any feedback on this ? Any help is appreciated.
Thanks
Ivan
 Post subject:
PostPosted: Mon Jan 10, 2005 4:22 pm
Ivan,
I would recommend a Rim drive Trainer, it mounts to the rim of your wheel so that there is no tire wear and no noise caused by tire knobs.
I don't know if rim mount is available as a fluid trainer, but mine is a Minoura mag drive. heres a photo of the rim drive, it doesn't even touch the tire
 Post subject:
PostPosted: Mon Jan 10, 2005 5:32 pm
Yes a trainer will chew up your tire!
I have a cycleops fluid trainer. It will put a flat spot on your tire. My solution was to buy a cheap heavy tire that I switch out in the winter and use for only my trainer. If your going to ride a MTB on your trainer don't do it with regular tires, the noise will drive you crazy. Go buy a cheap wire bead slick tire and use that.
www.altituderacing.com
 Post subject:
PostPosted: Fri Jan 14, 2005 2:09 pm
Continental have a special tire only for trainers. Look here:
http://www.bike-components.de/catalog/p ... ts_id=9731
 Post subject:
 Post subject:
PostPosted: Tue Jan 18, 2005 12:50 pm
Buying a special tire for my trainer, hmm sounds interesting indeed. I could also buy a special rear wheel (very cheap and heavy but that doesnt mather) mounted with a heavy tire.
A rim drive trainer also sounds interesting. I'll check those two. Thanks for the ideas.
There are no new unread posts for this topic. Don't really understand the difference between the Flux and Kura B+ trainers..
in Training
Shrike
Sat Nov 19, 2016 3:50 pm
Shrike View the latest post
There are no new unread posts for this topic. Upcoming generation of indoor trainers - any advice?
in Training
Shrike
19
1678
Sat Oct 22, 2016 1:03 am
TheKaiser View the latest post
There are no new unread posts for this topic. I've never used rollers ...
Valbrona
10
719
Mon Feb 13, 2017 4:49 pm
Rick View the latest post
There are no new unread posts for this topic. Which is more accurate, generally, smart trainers or crank based power meters?
Shrike
15
851
Mon Mar 27, 2017 12:38 am
HakeemT View the latest post
There are no new unread posts for this topic. Rollers vs turbo
in Training
buc
42
5780
Mon Mar 27, 2017 6:58 pm
saeie1 View the latest post
Users browsing this forum: No registered users and 2 guests
