Wahoo Kicker Vs Tacx Neo ?
- Moderator
It's not one sided at all as it measures both sides... By your logic is should be measuring the NDS hub forces.
Also where is it stated that Stages make the power meter in a Kickr?
Correct me if I'm wrong but the Kickr uses on board strain gauges paired with flywheel rpm and input resistance to deliver a power figure using their on board processing?
Using Tapatalk
Nefarious86 wrote:It's not one sided at all as it measures both sides... By your logic is should be measuring the NDS hub forces.
Wahoo says Stages makes it. Apples and oranges you get one power reading not two agreed?
The unbearable wallet lightness of being a weightweenie
- Moderator
Link to Kickr/Stages information?
You get a combined leg reading, the same as a Powertap hub, Quarq, P2M or SRM. To get "two readings" you're using Vector pedals, Powertap pedals or a Pioneer dual sided unit.
Using Tapatalk
How stable is the Wahoo Kickr when doing some all-out sprints for 15 seconds.
https://www.cycling-review.net
- Moderator
I've never had an issue. If is set up right it doesn't really move.
Using Tapatalk
I have a KICKR and a Quarq. When on the trainer, I usually use the Quarq to check pedaling balance at various threshold values.
And the KICKR has a very stable base; Sprints should be fine on it as long as the bike has been clamped down correctly.
Cicli Barco XCr Road
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
Ray Maker of DCRainmaker spotted an updated version of the Wahoo Kickr during the Tour de France: http://www.dcrainmaker.com/2016/07/tdf2 ... teams.html
reknop wrote:Ray Maker of DCRainmaker spotted an updated version of the Wahoo Kickr during the Tour de France: http://www.dcrainmaker.com/2016/07/tdf2 ... teams.html
And here it is: http://www.competitivecyclist.com/Store ... -BK-ONESIZ
Interesting move of Tacx with a price of EUR 800,-
Hands-on: The new Tacx Flux Smart Trainer: http://www.dcrainmaker.com/2016/08/tacx ... ainer.html
mulletmaster wrote:Neos are cheaper here than kickrs. The noise differential would be worth a few quid to me with young children but the kinetic energy more. I ride in the TT position only and more and more evidence is coming out that we use totally different muscular firing sequences with differing kinetic energies. The kicks is akin to riding everywhere on a 3% gradient.
mai wrote:the noise difference isn't even funny. for me that's a difference between training and no training at all. with the neo i can work out even when the baby's fast asleep.
I will be checking out some comparison video's. I'm leaning towards the Tacx Neo if it is as silent as advertised.
what about the fan though. my fan is louder than the trainer (kickr) i think. i'm in a relatively hot climate and so i guess an issue for me. but i would have thought even in the depths of a northern winter if you are indoors training you'd need a pretty serious fan no?
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
mrgray wrote:...but i would have thought even in the depths of a northern winter if you are indoors training you'd need a pretty serious fan no?
True. I use a fan as wide as my handlebars and it is standing just in front of the bike, at the same height that my face while riding. I would never survive the trainer rides without the fan.
mrgray wrote:what about the fan though. my fan is louder than the trainer (kickr) i think. i'm in a relatively hot climate and so i guess an issue for me. but i would have thought even in the depths of a northern winter if you are indoors training you'd need a pretty serious fan no?
My fan is louder then both the kickr and neo put together
I don't know how the kicker is cooler ? Bogus?
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Wife and I ride trainers together and have 3 fans plus a thin tower speajer to play music, so during training, our Neo's could be screaming and we would not hear it.
- Michael
