Feet swell up and hurt in hot weather!
Has anyone else had this problem? And how do you solve it?
I live and usually ride in northern europe, and have had no problems there for several thousand kms. But this summer I've been traveling with my bike to southern europe, and have had around 35-38 degrees celsius (95-100 fahrenheit) during my training sessions. After around 2 hours this results in swollen and hurting feet especially around the big toe and 5. metatarsal joint on both feet. Even opening the shoes both a little bit and a lot doesn't seem to help. First after training, when I take my shoes of, the hurt stops.
- bikerjulio
I was getting this too, especially on my Cuba rides. Removed insoles, problem gone.
There's sometimes a buggy.
One.
One.
Bigger shoes
I struggled with this exact issue for years. Long rides on hot days, especially in the mountains.
I found a very simple solution. I have a pair of shoes one size bigger that I use in very hot weather/for long rides when it's hot. Same shoes as my 'standard' shoes (Giro Factor).
Problem solved!
Problem solved!
- Stolichnaya
Bigger shoes are probably a good bet but may feel awkward.
Have you checked whether you should be running a wider Q factor in general?
The pressure point there is often an indication that your feet are trying to spread out. A wider stance might alleviate that stress.
You could also look into canting the shoe with a shim (Wedges, etc.) to see if that addresses the problem.
But if this is happening on hot days after a few hours only, it is probabl your feet swelling and pressing up against the shoe.
Thanks guys. My shoes are Sidi Wires, and they are the exact right size - I'm not using insoles. My cleats are pretty new still. I guess a bigger size would help. Maybe a cheaper bigger shoe would work, for the few days I'm riding in hot weather.
KH wrote:I struggled with this exact issue for years. Long rides on hot days, especially in the mountains.
Problem solved!
thats what i do.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Multebear wrote:Thanks guys. My shoes are Sidi Wires, and they are the exact right size - I'm not using insoles. My cleats are pretty new still. I guess a bigger size would help. Maybe a cheaper bigger shoe would work, for the few days I'm riding in hot weather.
maybe look at a wider shoe. Sidi makes wide ones...but since i switched from Sidi to S-Works, i haven't had those issues at all. right now, i'm wearing half size larger shoes...and are the ones i usually ride with. on winter days, i'll put thicker socks on, so i've been using the same shoe. i have the correct sized shoe...and use them in spring and fall.
- Factor LS Disc
- Factor LS Disc
