Calf muscle imbalance
- Resident master of GIF
- Contact:
logy wrote:Hi All. Any ideas what could cause a growing imbalance in calf muscle size? I am right-handed and the inner muscle on the left leg is a lot smaller than the right and seems to be getting more different?
dang maybe u should see a doctor. if size is the difference, that seems to be a product of Iliac artery blockage .... im not a doctor at all, but i recall a few riders noticing different size of leg muscles
Lots of reasons -- different arch on one foot, different pedal stroke, past injuries, etc. If you aren't having any symptoms, it's not clear what a physician will tell you. If you ride just one bike, you might be sure you don't have a bent pedal or crank arm. Be sure you aren't riding asymetrically on your saddle. If you can get on a power meter that gives true two-sided measurements, you can see if you are favoring one leg (I'm guessing that's the most likely reason, followed by pedal stroke differences caused by unintended adaptation to past injuries, etc.). My two legs are different and it's quite common if you talk to physical therapists and sports massage therapists.
Agreed with 11.4.
As a old marathon runner and now as a Therapist, I can tell you I've seen many different shapes and sizes of calf muscles in my time. This includes on the same person. Usually I ask the client if he or she runs on a cambered road or drives an automatic car.
Nothing to worry about, as long as you don't have a strong "chocolate side", meaning a really favoured side.
As others have said above, i would look at leg length discrepancy, pedal stroke asymmetry and arch support. Could also be due to nerve issues - do you get sciatica at all?
Have you seen your L/R power split? I have a fairly consistent 45/55 L/R split and my legs are slightly different (you can't tell without a tape measure) which i've put down to S1 nerve compression resulting from a bulging disc. trying to consciously do 50/50 efforts leaves my left leg overly tired and sore.
