Curious question when sprinting, need advice
raptor03
by raptor03
Hi guys, just like to ask - When you accelerate from someone elses wheel and kick to start a sprint, do you guys feel like you're pulling too hard and lifting the front wheel off the ground a little? I feel it when I kick and it makes me feel very unstable. Anyone else feel like this or is this normal?
Is it due to poor technique or a poor bike fit? I'd like to correct it as it makes my sprinting very poor.
victorduraace
by victorduraace
maybe too high front end? show us your bike setup please :_
zirxo
by zirxo
Lean more over the bars and you should be all set.
Stoo
by Stoo
Never lifting the front end!
Rear skips sometimes but that's being too far forward..
'18 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'18 Giant TCR Advanced Pro 1 - R8000 - QuarQ DZero - SLR1
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'13 Giant Trinity Composite - U6800 - QuarQ DZero
Tapeworm
by Tapeworm
Even sprinters get it wrong:- https://c1.staticflickr.com/5/4007/4282 ... 87e4f6.jpg
Practice!
"Physiology is all just propaganda and lies... all waiting to be disproven by the next study."
"I'm not a real doctor; But I am a real worm; I am an actual worm." - TMBG
hna
by hna
Isn't Awang doing that on purpose?
11.4
by 11.4
hna wrote:Isn't Awang doing that on purpose?
I'm not sure where that was taken, but doing a wheelie just as he's losing a sprint? I don't think so. At least not intentionally. He does have a tendency to move way back on his saddle and lose some control, and riders around him have often commented on it.
11.4
by 11.4
First, if you really move too far back, you basically are setting yourself up to do a wheelie. Some riders do that, but if you watch Pervis or any of the French, or Hoy, you'll see how you should be pulling your butt inwards. That may take care of the problem.
Second, if you jerk with your arms, you will lift the front wheel. Some people try to make up for lack of core strength by pulling harder with the bars, in effect trying to brace the torso. Again, it can lift the front wheel temporarily.
Third, where is this happening? On a straight or a banking? If you are pointed uphill at all, it's much easier to lift your front wheel slightly because your center of gravity is rotated backwards.
Mostly we need to see photos. It's hard to make much of that problem without seeing what might be causing it.
drchull
by drchull
I did this a lot when I was younger. I usually probably had my shoulders and head up way to high too. I find now I try a much more Cavendish like position with head and shoulders down low, more flexion at the elbows, more aerodynamic in the sprint. Try to make circles with the hands as opposed to pulling up hard.
Also the track guys will all tell you it easier to accelerate in a lower gear. Often popping up the front wheel indicates you are trying to accelerate in to large a gear and so are pulling too much with your hands to compensate. Again i probably did this a lot more when I was younger because I had down tube shifters and so would shift up more in anticipation of sprint than I do now.
mattr
by mattr
AFAIK he is doing it deliberately. And he's been dqed for it more than once
Dalai
by Dalai
They are both throwing for the line which is just out of frame. Aussie Ryan Bayley was know for his throws...
Footage of Ryan throwing for the line - http://youtu.be/E7T_6GtZAGo?t=3m26s
11.4
by 11.4
Ray was a long time ago, but he had huge upper body strength and almost always wheelied. I don't think I've ever seen a Frenchman wheelie. They really work that out in their positioning and training. Ray's coaches tried to work with him on it, but couldn't stop it without slowing him down so they simply let it be.
djconnel
by djconnel
Be silky smooth. Pull back not up. If you practice with a power meter you'll see this results in more power.
raptor03
by raptor03
I run a 90mm stem & am on about a total of 18.5cm's worth of headtube + spacers in front. Pretty tall and mostly legs hence my setup. I've also noticed that I tend to touch the handlebars w my knees when standing - is this normal?
11.4
by 11.4
raptor03 wrote:I run a 90mm stem & am on about a total of 18.5cm's worth of headtube + spacers in front. Pretty tall and mostly legs hence my setup. I've also noticed that I tend to touch the handlebars w my knees when standing - is this normal?
If you move too far forward while standing you can certainly touch the handlebars. But I'm wondering about your fit. An 18.5 cm head tube, plus spacers, and you're riding a 90 mm stem? Something's probably wrong. I'm thinking you may be on a frame that's way too big. That short a stem on that big a frame means you aren't getting your weight forward far enough to weight your front wheel properly. You really need to post photos if you want any better assessment of what's going on.
