It is currently Wed May 24, 2017 11:23 am
Post new topic  Reply to topic  [ 48 posts ]  Go to page 1 2 3 4 Next
PostPosted: Thu May 29, 2014 6:51 pm
After finally killing the HR strap that came with my 705 (and having a short and very underwhelming run with a Premium Garmin HR strap - died in less than a year), I need a replacement.
Anyone tried a PRO SCIO W4.1
http://www.madison.co.uk/products/cycli ... tic-strap/
otherwise looking like I'll go a Suunto.
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Thu May 29, 2014 7:12 pm
I replaced my Garmin strap with the Polar Soft Strap. There are rubber grommets around the contact points that you have to cut down flush with the contact points in order for the Garmin HR transmitter to snap in. No problems so far, been about 4 months.
http://ddubcustomsportswear.com
PostPosted: Thu May 29, 2014 7:33 pm
Resident master of GIF
x ∞
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
PostPosted: Thu May 29, 2014 7:47 pm
i replaced my Garmin strap with a CycleOps HR one. most of the HR straps are very similar is size.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 4.5 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Thu May 29, 2014 7:52 pm
To be explicit, I have the older one that came with the 705. Ie
http://www.wigglestatic.com/images/garmin-hrm-zoom.jpg
The Premium one was thrown out, as it didn't work any more. So counts out using any part of that as a hybrid with a Polar strap.
The Gram
The Men of Steel
PostPosted: Thu May 29, 2014 10:56 pm
Wouldn't the 705 still receive the same HR signal as say the Edge 500? If so, maybe you could just get the 500 HR transmitter and strap. :noidea:
PostPosted: Thu May 29, 2014 11:14 pm
:doh:
Yes, that's precisely my question. What ant+ compatible heart rate strap have people found to work well - comfort, longevity and function wise.
Sorry, I thought that was clear in the opening post...
The Gram
The Men of Steel
PostPosted: Thu May 29, 2014 11:20 pm
I use this Motorola one.
https://www.amazon.com/dp/B006K0PFEU/re ... us?ie=UTF8
It has worked well for me so far.
Also, it is quite comfortable.
Sent from my Nexus 6 using Tapatalk
PostPosted: Fri May 30, 2014 9:42 am
Administrator
You Pro's are hard on your equipment. :shock: I use the premium strap although with that said they seem to only last two years or so and then I'm buying another one. For me while its a PITA kits sort of like replacing worn out components on the bike.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri May 30, 2014 9:54 am
Per twitter, I am using a Cyclops strap however I am using the Garmin pod with it as the Cyclops HRM died after some 400hrs. The Garmin pod clipped straight on.
My Training & Racing Blog -->http://mountainbikemediocrity.wordpress.com
Fuelled by --> http://www.pro4mance.com.au
PostPosted: Fri May 30, 2014 10:08 am
Using my powertap one.
Exceptionally long battery life and comfortable.
It must be good; its outseen 4 lots of hub internals :?
Official cafe stop tester
PostPosted: Fri May 30, 2014 11:22 am
I replaced mine with http://www.mioglobal.com/Mio-Link-Gray/ ... vQodCloAew
PostPosted: Fri May 30, 2014 1:20 pm
Also using the cycleops one. Been OK.
PostPosted: Fri May 30, 2014 3:17 pm
24 months with a premium one and still going, I wash it after every ride tho.
Using Tapatalk
PostPosted: Fri May 30, 2014 4:23 pm
I switched to mio link as well. Seems to work alright. Less 200bpm spikes anyway.
There are no new unread posts for this topic. Lazer's Z1 and LifeBEAM heart rate...
CharlesM
Sun May 29, 2016 1:30 pm
BRM View the latest post
There are no new unread posts for this topic. Pairing heart rate monitor with iPad
in Training
joeyb1000
Mon Nov 21, 2016 6:44 am
kulivontot View the latest post
There are no new unread posts for this topic. Confused: tired legs, good power but low heart rate?
in Training
calleking
15
1588
Thu Mar 30, 2017 10:48 am
sib View the latest post
There are no new unread posts for this topic. screwdriver size for Garmin hrm battery replacement
in Training
alanmclean
9
1032
Wed Aug 31, 2016 7:46 pm
alanmclean View the latest post
There are no new unread posts for this topic. Recommend a (cross body) camera strap for riding?
prendrefeu
16
968
Sat Aug 27, 2016 7:27 am
seanmolin View the latest post
Users browsing this forum: No registered users and 6 guests
