It is currently Tue Jan 16, 2018 8:53 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Apr 10, 2014 1:05 pm
Hi,
I've got a powertap that I switch between two bikes, my training bike and my race bike.
I commute on my training bike and use cheap SPD pedals and heavy shoes. It dawned on me the other day that my power readings might be different between bikes as power is being measured at the hub, and there are fairly significant differences between the shoes / pedals / drivechain on both bikes.
My SPD shoes are over 300g each heavier than my race shoes, and the weight difference between my bottom of the range SPDs and my Dura-Ace's must also be significant.
But then I also have the weight advantage on the down stroke......
I know this is going to be marginal, but thought it would be interesting to discuss whether there is an impact?
PostPosted: Thu Apr 10, 2014 1:16 pm
I think you could easily have a different drive train loss between the two bikes that could account for an equal/more loss.
PostPosted: Thu Apr 10, 2014 6:32 pm
Your race bike likely takes less energy to ride at the same pace.
While it is a torque reading and im not sure how cycling systems use it, you will need as much energy to pull the heavy pedals up as it (the weight) helps going down.
PostPosted: Thu Apr 10, 2014 6:44 pm
Heavy shoes can really increase your output power, but only if you take your foot off the pedal during each "upstroke", So the weight of the upstroking shoe doesn't work against the gravity pulling down the downstroking side. Then you have to switch feet really fast for the next half of the crank rotation.
It takes skillful coordination.
PostPosted: Sat Apr 12, 2014 2:17 pm
I've noticed, although I can't say with 100% certainty, but I had about a 5 Watt difference in 20 min power when switching between shoes.
The lower reading came with a pair of Sidi Energy, heavy, nylon sole etc etc and the higher power output with a pair of DMT Radial, so, stiffer, carbon sole, lighter.
I don't think the weight had anything to do with it, probably the stiffness, if anything. I'm using a Quarq though, so I wouldn't see any drivetrain losses which are probably relevant in your case as well.
K2
Do you suffer more when you train, or cannot train?
There are no new unread posts for this topic. power2max problem - high readings
wwnick
18
1878
Sun Jul 30, 2017 10:52 am
wwnick View the latest post
There are no new unread posts for this topic. Impact of different Q-factor when switching between road bike and MTB
in MTB
Pieter
Thu Jun 29, 2017 5:58 pm
LeDuke View the latest post
There are no new unread posts for this topic. Oddball request: Indoor cycling shoes? Spin class shoes?
in Training
kkibbler
7
1084
Sat Mar 11, 2017 2:38 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
1965
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
Users browsing this forum: No registered users and 3 guests
cron
