It is currently Wed Jan 17, 2018 11:25 pm
PostPosted: Wed Mar 26, 2014 9:03 pm
How do you tackle strong headwind during your spring base training? We have flat landscape, a lot of open fields and a lot of wind in spring.
By "a lot" I mean going 23km/h and barely able to keep the HR below 150. Once there is tailwind, you can push 33km/h with a HR of 138 and up to 38km/h with 145-148 HR.
Should I keep my HR in the correct zone and do intervals when the race season is approaching - or keep the speed reasonable so I don't develop the so-called "speed barrier".
I know group riding would make that question obsolete, but my daily schuledule is floating all the time, so I can't join others.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
PostPosted: Wed Mar 26, 2014 10:29 pm
You should train in you HR zones. If that means popping it in an easier gear and going slow to bring down the HR and bring up the cadence, so be it. Time spent in specified hr zones (and cadence) is what's important - not speed.
Speed barrier - no such thing. Stick to your program (assuming that it's well thought out, progressive and measurable).
Cheers :)
PostPosted: Wed Mar 26, 2014 11:04 pm
Treat the wind like you'd do climbs. Shift down to the gear that has you working at your desired intensity when you're riding into the wind, and shift up when you have a tailwind.
If you have a programmable computer like a Garmin 500 consider setting the screens to not show speed so you're not tempted to match speed instead of intended effort.
PostPosted: Wed Mar 26, 2014 11:05 pm
I live in much the same type of environment (which would explain all the windmills) - 20-30mph (30-50kp/h) winds are nothing out of the ordinary here for afternoon rides. I prefer to keep my heartrate and power consistent within my training program, rather than worry about the speed. Once you hit a tailwind, it becomes a bit of an equalizer in terms of average speed (although the wind never helps as much as it hurts).
PostPosted: Thu Mar 27, 2014 2:57 am
That's what the 34-25 is for. Go for as long as you can until your brain turns to mush, flip and enjoy the fun going home.
PostPosted: Thu Mar 27, 2014 9:23 am
Administrator
We too have high wind in Spring and Fall. Flat and open too. I run a standard crank and an 11-21 cassette. In Spring I just ride it and do what I call make peace with the wind. You get stronger and used to it. By fall your level of fitness just deals with it. If a real big wind day in the fall, 30 mph plus, do a wind aided ride since its the end of the season and time for some fun on the bike. Get someone to drop you off and let the wind blow you back.
RESIDENT GRUMPY OLD MAN.
PostPosted: Thu Mar 27, 2014 2:14 pm
There's a lady here where I ride that will only ride with a tailwind. She calls her husband to pick her up when she's "tired". Then she brags about her 80 mile ride, averaging 22mph!
PostPosted: Sun Apr 06, 2014 1:51 am
As they say... Tailwinds don't make up for the headwinds!
my YouTube channel- keep the grams down and the watts up!
-2014 Cipollini Bond Campagnolo EPS -2011 Time RXR ULTeam SR11 -2010 Colnago EPS SR11 -2013 Colnago C59 SR-EPS -2011 Colnago Prestige Di2 -2013 Specialized Shiv TT SWorks SR11
There are no new unread posts for this topic. How much base ? When to start structured training?
in Training
AJS914
Fri Jun 30, 2017 8:02 am
AJS914 View the latest post
There are no new unread posts for this topic. Base Training: Traditional, Sweet Spot, or both?
in Training
JBeauBikes2
26
3678
Mon Aug 21, 2017 11:10 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Lightest aero base bar + stem combo? (separate or integrated)
alcatraz
Fri Aug 18, 2017 10:52 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Which wheels for training
in Everything wheels
JScycle
12
1914
Sun Jun 04, 2017 9:43 am
JScycle View the latest post
There are no new unread posts for this topic. Training book
in Training
Tomstr
Tue Jun 13, 2017 9:14 pm
Tomstr View the latest post
Users browsing this forum: No registered users and 3 guests
