It is currently Tue Jan 16, 2018 2:50 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Mar 13, 2014 1:14 am
I didn't see any other threads on BSX Insight...there's a Kickstarter project for a device which measures lactate threshold using a wearable sensor on your calf muscle. Seems they've been working on it for a while now, but they're projecting delivery at the end of the year. Certainly would be great if the technology worked and the device could be used independent of their web-based training system (i.e standardization of ANT+ or BTLE sensor profile for lactate measurement).
https://www.kickstarter.com/projects/16 ... er-athlete
Pro-Lite Cuneo
PostPosted: Thu Mar 13, 2014 8:25 pm
If they can do non intrusive lactate measurement like this, that's a nice achievement in itself.
"Unfortunately", lactate has been largely disproven as a performance indicator in recent years. Some of the fastest Kenyan marathon runners train not to run as fast as possible at a given lactate level, but rather work on being able to produce and process as much lactate as possible. Read up on what coach Canova has to say about it, if interested.
PostPosted: Thu Mar 13, 2014 10:32 pm
Thanks for the tip on Canova. Based on a few lay-person articles that I read, his training theory seems to be consistent with comments made in this forum.
I'm not sure if I understand you correctly, is there no training/analytical value in capturing lactate measurements?
Pro-Lite Cuneo
PostPosted: Sat Mar 15, 2014 10:53 am
Yes, my layman's understanding is that there is little value. Say you can sustain (whatever) 3.5mmol for an hour. Then you so some training for a few weeks, and find out you can now sustain 4mmol. That doesn't mean you've become better or worse, just you trained in a way that increases lactate turnover. Will try to find back a relevant article.
PostPosted: Sat Mar 15, 2014 4:14 pm
Well, lactate on its own will not say much until it is paired with other metrics.
The point of the product is to make it possible for the average Joe athlete without access to lab testing to find correlations between lactate/heartrate/power to validate whether or not a training plan is working over time, besides actually the pacing standpoint.
But until there will be an ANT+ profile for lactate metrics that could be extracted from within GoldenCheetah or other software, I do not have much use for the product myself.
PostPosted: Sat Mar 15, 2014 9:22 pm
Here's the article pointing out issues with common lactate threshold approach http://www.scienceofrunning.com/2007/01 ... is-it.html
Personally (and others have said so here before), I think it's much simpler and more reliable to base your training on something that is easier to measure and more reliable to interpret -- such as FTP. If you do the same FTP test periodically, you will see whether you improved, and what the difference is. The lactate, VO2max etc parameters your body exhibits, are secondary.
PostPosted: Mon Mar 24, 2014 3:39 am
It's an interesting technology, but my main interest in the tech doesn't parallel how they are marketing the product.
I think Sm02 is more valuable information than the lactate measurement. If you can monitor Sm02 you can pretty accurately pinpoint the aerobic/anaerobic switch, zone, or level. You'd also be able to gauge the effectiveness of your anaerobic intervals to verify your target wattage is sufficiently de-oxygenating the tissue, and that you're adequately recovered from that interval to hit it again. The really interesting part is that they seem to be collecting that info, but then use it to calculate lactate.
There are folks that claim the only metric that matters is power, and they're right. If you can't muster the watts to bridge up, or remain with the group on a climb, then that's that, you've failed. The ability to do the work matters most.
What they fail to take into account is that lactate measurements tell a fair bit about how your body is making power across a wide power curve, and the ability to monitor that curve over time tells an interesting story, and for me personally, has completely changed the way I use my power meter to begin with.
Taking a multidimensional approach to analyzing your power curve is worth while, and having the ability to monitor Sm02 would really be quite interesting.
I have my own reservations about the traditional definition of FTP. The number is a moving target, and the work you're able to do relative to FTP is influenced by a number of variables, diet, hydration, fatigue, recovery, etc. The thing that I've noticed is that on bad days with fatigue when you struggle to make power, or after getting dropped on a climb, that wattage I settle in at, is, you guessed it, lactate threshold. If anything it has been more consistent for me than traditional methods of FTP testing. My best 95% of 20 min tests are a solid 35w more than lactate threshold, and 40k TT power has been maybe 20w or so higher, FOR ME. I generally do my lactate test and power testing very near each other after training blocks, and use 1/2 way between the two as my FTP, and even then I know my Sweet spot is below suggested % we traditionally use to find it.
What regular lactate testing has taught me is that, a) I used to train far too hard when I was trying to train the aerobic engine, b) I wasn't consistently training hard enough anaerobically , and c) that my increase in FTP was largely from anaerobic intensity work.
Which meant I was passing up the bump in FTP from doing adequate aerobic work, the gains I had been making were quick(er) to leave with decreased training volume and intensity, and the work I was doing that was increasing my FTP was too easy, and too infrequent.
To end a long rant, I'm two months closer to my high water mark of last season, and I've ridden far less this early season than past years.
There are no new unread posts for this topic. Anyone use a muscle oxygen sensor monitor?
in Training
53x12
Thu Jun 15, 2017 5:38 pm
kode54 View the latest post
Users browsing this forum: No registered users and 5 guests
cron
