It is currently Sun Jun 25, 2017 6:28 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 31, 2014 6:33 pm
Start "easy". As in 5-10 watts below your target, then ride on your target when the climb starts properly. A negative split is very often the best tactic for hill climbs. A lot of people starts way above their sustainable effort and blow up towards the end of the climb.
PostPosted: Fri Jan 31, 2014 10:30 pm
Not sure about that negative split thing. Some of the best climbers I know go out on middle-distance climbs hard then suffer to the finish. I've done good timed both on a steady pace and going harder, then managing the fade. The argument for a fast start is this assures you use your available anaerobic resources. The downside is if it's a long climb you'll pay interest on this later. But if it's on order 15 minutes "later" may be manageably short.
On the steep-versus-gradual: Tapeworm nailed it. Slightly more power on the steep, but adjusting for enthusiasm, "slightly more" feels "ridiculously easy".
And my princple is "if it doesn't make me faster, it makes me slower." Do sunglasses make me faster? Out. Gloves? Out. Watch? Only if I need it to make my start time. Otherwise out. HRM strap? Out. I do take my Garmin 500 because I like a record of how I did.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Fri Jan 31, 2014 10:40 pm
It depends really. For me a negative split works best for an individual start on the middle-distance climbs. 5 to 10 watts for a minute or two isn't much and I make sure that I stay strong the whole way. Especially if the first minutes of the TT is somewhat flat. A flat pacing strategy might work better for others, though.
PostPosted: Sat Feb 01, 2014 1:16 am
And don't ride back down :shock:
natefontaine wrote:
130psi Front and 140psi Rear
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Sat Feb 01, 2014 6:18 am
I was ~64kg that day and rode my Caad9 ~6.4kg. As for starting a TT, you need yo get up to speed. 15s at ~600w should be fine, then hit 10w below your estimated max 10min power and suffer till the bitter end.
1st 500 in the drops hoods and tops the rest.
PS. I would just let some air out for the descent. (Just looked at my notes...150/160psi that day ;)
Sent from my SPH-L900 using Tapatalk
S-WORKS Venge 2012 - 7.3 kg
Allez E5 - 7.3kg
DengFu FM086 - 8.3kg
CAAD9 - 6.32kg
PostPosted: Sat Feb 01, 2014 9:01 pm
Resident master of GIF
holy moly!
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
PostPosted: Tue Feb 04, 2014 7:11 pm
Looks to me like your power trended down in the 2nd half.
I think not popping it out of the start and holding power slightly down in 1st part would have helped your time.
Started too hard-
natefontaine wrote:
I know that course, below is my power file from it. I think that I could have saved some time if I focused on my speed in the switch backs. Power surges out of the saddle to keep momentum might have been the only way I could have gone faster.
http://tpks.ws/t7FC
I would also recommend:
Aero as possible, 130psi Front and 140psi Rear, tight range cassette 11-23 or 21.
PostPosted: Thu Mar 27, 2014 5:11 pm
tomorrow is the big day. thanks for that training peaks data, nate. you went harder on the first flat part than I would have thought was best, but it's hard to argue with your results!
as regards your question, ryan, I've talked with lots of people on this topic and the consensus is consistent with your premise that you want to exert more effort on the steeper grades. and that you want to end up depleted after a consistent draining of energy, but with a hard push in the last few minutes.
there are markings on the course at 1k, 2k, and 3k to go (I reconned it Monday, just after you and i met up).
my buddies leibert and konsmo have it pretty well figured out. I predict konsmo is going to rock it, given his recent training data.
PostPosted: Thu Mar 27, 2014 7:18 pm
Just be careful not to exert too much effort on the steep parts.
Yes, and don't over do the beginning. Nothing feels worse than blowing up half way through and crawling the rest of the way.
formerly rruff...
PostPosted: Fri Mar 28, 2014 6:00 pm
It never feels hard at the start- that is why it is so easy to overcook it.
As WMW say, keep harder punches on hard parts to 5-10%.
You want to be full gas in 2nd half- when you blow it, it still feels just as hard (or harder than when you get it right).
There are no new unread posts for this topic. Cervelo R2 - Hill Climb Project
JLS
9
1430
Mon May 15, 2017 2:38 pm
BmanX View the latest post
There are no new unread posts for this topic. Mt. Washington Hill Climb Strategy
Pan
11
737
Fri May 26, 2017 4:20 am
kulivontot View the latest post
There are no new unread posts for this topic. How do you train for something specific like a hill climb segment?
in Training
Shrike
Mon Mar 27, 2017 4:15 pm
Shrike View the latest post
There are no new unread posts for this topic. Congrats to JamieL - 3rd in UK National Hill Climb!
MattSoutherden
13
1463
Thu Nov 17, 2016 5:48 pm
nobuseri View the latest post
There are no new unread posts for this topic. Attachment(s) Cervelo R3, stripped, drilled, Di2 UK Hill Climb bike 5.4kg
Rudi
11
2589
Fri Nov 18, 2016 2:00 pm
Rudi View the latest post
Users browsing this forum: No registered users and 4 guests
