I gotta pee!
by xnavalav8r
Hey guys. Potty questions are always a bit embarassing. But after three months off the bike (while at sea) I am back into my daily commuting routine. However, I have noticed that I need to stop and urinate once or twice during my 90-minute ride. This wasn't the case a few months ago. I'm not aware of any other change in my daily routine. But, in hindsight, I seem to recall this being the case about a year ago after a similarly long break from cycling. Anyone else ever experienced this?
Is this just my body readjusting to the routine? Should I be worried?
by PSM
You're getting older. Comes with age. How old are you?
More things can/will happen to you...
by xnavalav8r
Iḿ only 42 and all my plumbing works fine. I did a little experiment this morning and simply drank half a glass of water with breakfast instead of a full glass. No pit stop today. Maybe I was just over-hydrating...
by fitty4
If I feel the urge to drink within half an hour before training I need to just take very small sips otherwise I need to go sometimes every 20 minutes
by NoiseBoy
Do you need to go more frequently than usual when off the bike? If so it's worth seeing a doctor.
by xnavalav8r
Nah! Off the bike everything is normal.
I've been consciously drinking less before my ride and have had no problems.
by Foo
Do you have a coffee before the ride also? :?
So long as you have tried your best, then you should have no regrets!
by myndog
peddal harder. You will swet all the pee :D
