It is currently Thu Dec 14, 2017 7:37 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Jun 27, 2013 10:16 pm
I've been riding with my power meter for more than a month now and find it incredible hard to keep a somewhat steady output when doing longer intervals (threshold), even on my trainer.
The average power for my intervals usually ends up within +/- 10% of what I planned, but when I checkout my data afterwards, my power curve is one giant sawtooth with serious time spent far above my intended power.
On the bike I try to pace myself with the 3s avg. power use 30s+lap avg. power to see a "trend" of how I am doing.
But how do you learn to ride economically to avoid the sawtooths in power output? Higher cadence? Mashing? Pedal-hold-pedal?
PostPosted: Thu Jun 27, 2013 11:47 pm
What PM are you using?
What head unit?
What trainer?
What interval length?
etc.
We need that info first mate.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 28, 2013 2:10 am
:idea: Could be due to a less than perfectly round pedaling action which applies a perfectly constant force throughout the entire pedal revolution. +-10% seems like a lot of variance, but it would be incredibly difficult to maintain, say, a 300 + watt interval within 5 watts. Somewhere in between seems acceptable.
PostPosted: Fri Jun 28, 2013 7:21 am
What head unit?
What trainer?
Crank based power meter (Power2Max) with a Garmin head unit. Trainer is an Elite magnet based one. Intervals usually 2x20 or 1x40 done outside. I don't think that any of the gear is faulty and that the problem instead lies within my technique.
I am far from the smoothest rider, but I dont think the spikes are due to my pedal stroke. I often ride at FTP on the flat, just to look down at the Garmin a moment later with 3s power spiking 50% above FTP.
How tight wattage ranges should you be able to keep within on a flat road for somewhat normal conditions (no traffic, little wind and no sudden hors categorie climbs)?
PostPosted: Fri Jun 28, 2013 8:59 am
It's the same on road as the trainer?
I use 3sec power for my pacing/training/pretty much everything. 30sec is too long.
Able to post a screen shot of a typical session? Road and trainer.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 28, 2013 10:20 am
Hi again,
I'll try to sort out some graphs and post!
I thought about the possibility of my FTP being too low, as whenever I am fatigued after a long ride or applying force enough to ride within what is now Z5, I find it so much easier to keep a steady power. Doing 2x20 intervals at 95-100% of FTP shouldn't feel easy, right?
PostPosted: Fri Jun 28, 2013 2:16 pm
z5 is Vo2 max. So yes, sounds like FTP is too low for starters.
When was the last full-noise 20 minute test?
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 28, 2013 3:35 pm
My power graphs also look spikey. I just go by 3-sec ave, power readout and also have "lap power" displayed.
If you zoom in to a short interval it will look less spikey, but still seems a lot more variable than it feels while doing it.
PostPosted: Sat Jun 29, 2013 12:26 am
Here is a shot of a 20 minute interval of mine (on my Lemond trainer) this week
if yours looks like this, I think you've nothing to worry about.
VeloKicks
The Gram
The Men of Steel
PostPosted: Sat Jun 29, 2013 1:02 am
FWIW: When riding on a trainer with power, if I try to maintain a set power - it's more variable than I'd like. If I try to maintain a cadence, things smooth out more.
PostPosted: Mon Jul 01, 2013 5:11 pm
Thank you!
I did a 2x20 yesterday on the trainer after increasing my FTP about 10% and increased the sampling rate of my Garmin (which somehow got reset to a low value in an update) and now my files look much smoother again!
PostPosted: Tue Jul 02, 2013 1:08 am
1 sec sampling is what you need to have it on. Not smart recording.
And include zeros.
VeloKicks
The Gram
The Men of Steel
There are no new unread posts for this topic. question about pacing
in Training
addictR1
16
1523
Wed Jun 14, 2017 4:44 am
addictR1 View the latest post
There are no new unread posts for this topic. Riding in strong winds.
KCookie
21
1348
Sun Dec 03, 2017 12:40 am
KCookie View the latest post
There are no new unread posts for this topic. Santa Fe, NM riding advice
53x12
13
980
Wed Aug 16, 2017 2:39 pm
kytyree View the latest post
There are no new unread posts for this topic. Riding in the Provence - Luberon
benzebub
11
663
Tue Jul 04, 2017 3:54 pm
Digger90 View the latest post
There are no new unread posts for this topic. Big Slicks for Gravel Riding
morganb
Mon Dec 11, 2017 2:31 pm
spud View the latest post
Users browsing this forum: No registered users and 4 guests
