It is currently Sat Dec 16, 2017 7:54 pm
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Jun 13, 2013 1:54 pm
Thanks for that very interesting study KWALKER. It seemed to corroborate well with my personal situation. I have been racing and training a long time, since before power meters were generally available. So 80-90 RPM is where I would have guessed I produced maximum power, based on RPE and general subjective assessment. So after I started riding with a power meter it was disturbing that the average power numbers were always actually higher when mashing a huge gear at low cadence. I guess this is not a totally unique occurrence.
I am aware of all the other considerations too: big gears make it difficult to respond to sharp attacks, etc....but a lot of times it just comes down to going as hard as you can to the top of the hill, or time-trialing across a gap, etc.
PostPosted: Thu Jun 13, 2013 2:00 pm
I need to mash more!
PostPosted: Thu Jun 13, 2013 2:23 pm
It also remains a fact that all the hour records were set with cadences of ~100RPM. So maybe elite athletes are elite because they have a higher percentage of fast twitch fibers that actually are more powerful/ efficient at high RPM. I am certainly not "elite" and I am treading at the low side of "mediocre". :unbelievable:
PostPosted: Thu Jun 13, 2013 2:34 pm
Keep in mind, "mashing" does not mean "pedalling slower".
Also, it has suggested that over the course of an athlete's career Type 2b* muscle fibres are actually recruited and behave more like Type 1 fibres. Which is why the top Pro's can hold speeds that we are pushing into our anaerobic capacity to maintain while they are still well within their aerobic zone.
*quite sure it's Type 2b, will stand corrected though
VeloKicks
The Gram
The Men of Steel
PostPosted: Thu Jun 13, 2013 3:19 pm
Can you elaborate on that ?
When I got into cycling, smooth spinning was emphasized. So I always suspected that I actually "wasted time" worrying about a smooth stroke and should have spent more time simply pushing down hard on the pedals. As a result, I do have a pretty smooth spin and have spent many hrs spinning away at high cadence in criteriums, etc. ...it just doesn't produce as much power for me.
PostPosted: Thu Jun 13, 2013 3:38 pm
Please take a look at this
http://www.peakscoachinggroup.com/%28S% ... adence.pdf
PostPosted: Fri Jun 14, 2013 2:19 am
We need you to get past this. Things have changed. Sorry Rick, don't mean to sound harsh - I just cannot think of how better to put this.
And I did
viewtopic.php?p=993955#p993955
cannot find the study at present, but there was a large analysis (in the USA I think) where they had cyclists ranging from Cat 3 to Cat 1 and Pro's. The 'smoother' and 'rounded' pedal strokes primarily belonged to the lower level riders.
As the level (and power) improved, the more the stroke was a 'mash'.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 14, 2013 2:39 am
They can be recruited as oxidative fibers, but its not as big as people would think.
Gramz
Failed Custom Bike
PostPosted: Fri Jun 14, 2013 3:05 am
Point was, it contributes more than was originally thought.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 14, 2013 5:44 am
No "harshness" taken. It has just taken me a long time to really accept that smooth spinning is really not all that effective and "mashing" really works! :)
But I infer that one can also "mash" at higher cadence, i.e. concentrate on a forceful "Pulse" on the downstroke of each pedal rotation, and without regard to the smoothness of the rest of the stroke ?
PostPosted: Fri Jun 14, 2013 8:23 am
Absolutely. The down stroke carries enough velocity that it whips the opposing 'up' stroke through.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri Jun 14, 2013 5:31 pm
why not forget all the pedal smoothness and cadence misonceptions alltogether?
Just focus on producing the required effort for the required time duration, then, post-ride analysis should take care of what cadence you naturally are using at different power output.
PostPosted: Fri Jun 14, 2013 6:59 pm
I can very well imagine that riding an artificially smooth stroke comes with an efficiency cost, even if well trained (hindsight is 20/20, too). The human physiology lends itself way better to loaded leg extension than (loaded) retraction. I can't think of any need to retract with extra weight in the evolution of hominids, am I missing something?
Edit: loaded retraction, for clarity.
PostPosted: Fri Jun 14, 2013 7:32 pm
Unless you retract you're also pushing dead weight... I'll bet the retraction costs less than pushing the dead weight... while I do agree that taking a smooth pedal stroke to the brink of perfection might not serve a purpose...
The Shivenge
PostPosted: Sat Jun 15, 2013 6:24 am
Good idea; that is how I got on to this idea in the first place. But I couldn't really quantify it until I had a power meter.
In the past, timed efforts always had some uncertainty due to weather conditions and day-to-day variations in perceived exertion. And when going by perceived exertion I always choose a higher cadence. It was only by noticing that the power was actually higher when pedaling at very low cadence that I started questioning. With the power meter it doesn't have to be post-ride, because I set the unit to show both 3 second power and power averaged over the interval. So it is instant faeedback with the average also displayed for any length interval I choose.
Then, I also thought that maybe I actually am "exerting" more at high cadence, but it is just inefficient exertion that does not translate into power to the cranks. It does make some logical sense that efficiency would be higher at low cadence, because you can imagine that if taken to extremes, you could flail away at high rpms in such a low gear that you are producing no power. But you can always stomp hard on the pedals even at very low cadence.
There are no new unread posts for this topic. power2max problem - high readings
wwnick
18
1783
Sun Jul 30, 2017 10:52 am
wwnick View the latest post
There are no new unread posts for this topic. climbing with high profile rim.. thoughts?
addictR1
23
2217
Sun Apr 23, 2017 2:07 pm
otoman View the latest post
There are no new unread posts for this topic. Colnago C50 PR11 High Modulus, now 6,6kg
SampsC50
24
3508
Sun Dec 10, 2017 6:36 pm
Look565w View the latest post
There are no new unread posts for this topic. Durable but high quality clincher
Vagabond
38
3375
Sat Oct 28, 2017 12:08 pm
CBJ View the latest post
There are no new unread posts for this topic. Weird bearing drag at high speeds ??
in Everything wheels
LouisN
Mon Jul 03, 2017 12:54 pm
bm0p700f View the latest post
Users browsing this forum: No registered users and 1 guest
