It is currently Fri Dec 15, 2017 9:04 pm
Post new topic  Reply to topic  [ 49 posts ]  Go to page 1 2 3 4 Next
PostPosted: Tue Jun 04, 2013 3:45 am
When I look at some of the pros going over high mountains, their high cadences seem phenomenal. Also, when I see the statistics for the hour record, and the wattages put out there for an hour at ~100 RPM, it boggles my mind.
In my own experiments, I can always put out the highest sustained power at very low RPM: 60-ish. So low that I am right on the hairy edge of not being able to turn it over at all. When I try higher RPMs, my power just falls off no matter how hard I try to spin.
I have always been a poor climber, So, I would just think it is my own lack of or faulty training, except that I know and ride with some truly excellent climbers who use both extremely low RPM and higher RPM. There are also certain examples in the pros who are effective at low RPM (Cadel Evans).
Also, I can never produce anywhere near the same power on the flats as I do climbing, even though I naturally do use a higher cadance on the flats.
So here is my question:
Is the cadance of maximum sustained power (like 20 minutes+) a genetic thing with wide variation, or is it a product of training ?
SHOULD I be trying to increase my climbing cadence, or SHOULD I just accept whatever cadence naturaly produces the highest power output and try to increase my power by traing at approximately that cadence ?
If it is a combination of both, then why is higher cadence "better". Why SHOULD I want to increase it ?
And is there data to support any of this, or is it just opinion and experience ?
I have been training and racing for many years, so it seems like I would have decided on an answer to this, and yet I still feel like I have no clue, only confusion.
Thanks
PostPosted: Tue Jun 04, 2013 8:22 am
Is this perceived power or measured by a powermeter? There is a difference between kg load on the pedals and watt and hence the perceived power seem higher at lower cadences.
Higher cadence has a lower muscular cost and a higher cardiovascular cost. You need to put more kg of force in the pedals in order to produce the same watts on a lower cadence compared to a higher cadence.
A higher cadence helps clear out lactate better, and it puss less strain on joints and muscles and is therefore less likely to cause injury. Up until a point of course. After you reach a high enough cadence (individual limit due to genetics, training etc), you will not have coordination enough to make your legs pedal efficiently throughout the stroke and have fast enough musclecontractions, causing your joints to fly all over the place.
PostPosted: Tue Jun 04, 2013 11:35 am
This is a very important question. After just a few months with a power meter, many of my preconceived notions were turned up-side-down.
PostPosted: Tue Jun 04, 2013 1:52 pm
It is MEASURED POWER. (Using a Power tap SL)
Part of the reason this bothers me is because I didn't have a power meter until a little over a year ago. If I had been going by perceived power I would definitely have thought my max power was at higher cadence. The fact that in repeated tests over the past year my power for anything over about 2 minutes is definitely higher at very low RPM is what has made me wonder about this.
And I realize that the conventional wisdom is that "Higher cadence has a lower muscular cost and a higher cardiovascular cost. " But when I am grinding away on a long hill I am pretty much pushing both my strength and cardiovascular limits simultaneously.
That is why I wonder if there is a reason to emphasize higher cadence, or if it is just a matter of continuing to push on the pedals harder at the "natural" cadence.
 Post subject:
PostPosted: Tue Jun 04, 2013 2:44 pm
You, personally, are more efficient at a lower cadence. Some people are. In the long run, though, your knees may not like that, so use them wisely. It is also likely that if you were to ride at 60 rpm for a few hours, your max power at the end (like in a sprint finish) would be lower than if you rode the same course at high rpm til the end.
Sent from my EVO using Tapatalk 4 Beta
PostPosted: Tue Jun 04, 2013 6:21 pm
I am the same. I can see it in the numbers as I ride, and then it is confirmed in the data afterwards. My much higher power in the hills means that I keep a hills FTP for training and then make an adjustment for what happens at higher cadence on the flat. What I am trying to do through cadence drills is to get the numbers closer together.
Previous posters are right - over a 3 hour ride, the low cadence numbers do fall off. I always talk about this as my numbers (FTP) is good, but with no depth (long ride / lots of matches).
PostPosted: Tue Jun 04, 2013 6:55 pm
Don't try to match pro cadence. Cadence is a trade-off between muscular force (bigger at low cadence) and aerobic cost (bigger at high cadence). The pros are stronger: they can tolerate more muscular force and more aerobic cost. But there's a good chance their advantage on the aerobic side is proportionately bigger than their advantage on the muscular side. Therefore their optimum point is at higher cadence.
It's great to train high cadences (working on a smooth spin) and low cadence (working on the force side), but when it comes to going as fast as possible, the sweet spot may be different than it is for Contador or Nibali.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Tue Jun 04, 2013 8:17 pm
I have even tried wiggling my ass exactly like Contador when out of the saddle. Nothing works! :oops:
Sometimes I think that I can produce higher power at low RPM just because I am so close to "stalling" that I know I have to keep it up or stop entirely, so I get little adrenaline rushes that keep me turning it over. Whereas at higher rpm I can "relax" a little almost unnoticably....and reduce the pain a little...so I do. The difference between 90 rpm and 85 rpm isn't that much, and then the difference between 85 and 80 isn't that much....until I am at 60 RPM. I just wondered if there was some deeper insights from others with similar experience.
PostPosted: Tue Jun 04, 2013 10:26 pm
What's your training background like?
PostPosted: Wed Jun 05, 2013 12:49 am
It's normal mate, there was a thread on this not that long ago over at the wattage groups, most there found their cadence to be much lower during TT's and longish efforts at or above FTP,
I'm the same I start a TT at ~85rpm and by the end I'm around ~70rpm avg being ~75rpm, years ago it used to be 85 - 100rpm if I try that now I blow up early.
Only difference now is I'm much more trained and putting out way more grunt, it's just done at a lower cadence, RR's are different and avg cadence varies alot but so are the demands of the races compared to iso efforts.
PostPosted: Wed Jun 05, 2013 8:58 am
I think it's what people have conditioned themselves into. It's really down to your muscle makeup and the way your body has been trained - for me it's totally the other way round. If my cadence drops below 80rpm I utterly stall. I can't get any power out because I just stall and die within 20 seconds. My cadence is usually comfortable up at around 110rpm but on the turbo doing longer intervals I find a sweet spot at around 120rpm. I'm very short and light with stick legs and I presume that I just have less muscle mass for raw power - I rely completely on souplesse, gearing and power to weight ratio to get me up those hills as fast as possible.
PostPosted: Wed Jun 05, 2013 9:23 am
Precisely.
I think it's conditioning, with some genetics also playing a role.
Fitter I got, higher cadence got. I don't average over 100 in TT's, but certainly higher than 60.
VeloKicks
The Gram
The Men of Steel
PostPosted: Wed Jun 05, 2013 7:09 pm
Now we are starting to get at my question:
Is higher cadence merely a byproduct of superior fitness, or should one train at higher cadence to gain superior fitness ?
Or stated another way: If one has attained superior fitness, then do they generally producer max power at higher cadence, or can one be in peak fitness but still just naturally produce max power at low RPM ?
Should one attempt to increase cadence as an end-in-itself, or is cadence always just a secondary parameter to where max power is achieved ?
PostPosted: Wed Jun 05, 2013 7:42 pm
Well, this guy isn't slow. He swears by the low cadence - that's just what he's trained to.
PostPosted: Thu Jun 06, 2013 12:00 am
Firstly cadence is NOT a measure of fitness, power is.
FTP is how hard you can go and CTL is how long you can go hard for.
Crank length, terrain, % of fast vs slow twitch muscle fiber you are born with and how much time you spend training at different cadences on different terrain will determine what cadence you choose when it's time to drop the hammer.
Also even though I may choose to TT at 75rpm, I also find that during some races I will choose to climb at ~95rpm for 10-20 min because I'm fresh and the the pace is not that high, it's below threshold, as the pace lifts my HR and PE rise therefore to stay in the game I'll need drop my cadence, many do this also, others choose to stay at the same rpm reguardless, doesn't mean they won't get dropped just because they climb or TT at a higher cadence than me or you.
I've been in many many races mostly handicaps here in Aus where guys are flying up climbs early on with what seems like insane ease and high rpm only to get dropped at the 120km - 140km mark when the going gets tuff and the real selections are made, so if high cadence is a measure of fitness something is off.
Of course I've been dropped many times myself due to lack of fitness not gear selection or cadence.
There are no new unread posts for this topic. power2max problem - high readings
wwnick
18
1761
Sun Jul 30, 2017 10:52 am
wwnick View the latest post
There are no new unread posts for this topic. climbing with high profile rim.. thoughts?
addictR1
23
2180
Sun Apr 23, 2017 2:07 pm
otoman View the latest post
There are no new unread posts for this topic. Colnago C50 PR11 High Modulus, now 6,6kg
SampsC50
24
3467
Sun Dec 10, 2017 6:36 pm
Look565w View the latest post
There are no new unread posts for this topic. Durable but high quality clincher
Vagabond
38
3351
Sat Oct 28, 2017 12:08 pm
CBJ View the latest post
There are no new unread posts for this topic. Weird bearing drag at high speeds ??
in Everything wheels
LouisN
Mon Jul 03, 2017 12:54 pm
bm0p700f View the latest post
Users browsing this forum: madik and 3 guests
